Launcher Pro Question.....
Except for calendar and task widgets if you make them full screen size.
The other great thing about GO Launcher is the numerous free and paid theme packs. It doesn't have a good calendar widget like launcher pro, so try Business Calendar or Pure Calendar in the market.
Sent from my SCH-I500 using Tapatalk
Thanks. I will take a look. I like their clock/weather widget a lot.
I have homeswitcher to toggle between whichever UI I prefer but when I set launcher pro as my default it will always go back to TW when I hit the physical home button on my charge. Could someone tell me how to keep LP as my default, its so much better than TW!
THX
THX
You should be getting a pop-up when you hit the home button asking which to use, and a checkbox to use which to use all the time.
If you aren't getting that pop-up, go into settings, applications, manage applications, then press on Launcher Pro. Clear defaults, then hit the home key, now you should get the pop-up.
Reactions: hockeymn25
noroldie
