Leaked DL30 Froyo Build Available NOW! (Includes Full Instructions: Updated 2/5)
Status
Not open for further replies.
I am Happy...On a word to the wise, I would not suggets anyone do a "Factory Reset" as it will reboot, then in some ladies very hot voice tell you" converting system partition, partition offline" then "converting ???? partition, system offline" I nearly wet my pants...but i'm all better now after flashing DL09 then back to FROYOOOOOOO
Problem is I'm not seeing Appbrain as an app that I can open on my phone? It seemed to download it, but it's not in my app list?
need help
Hi i am kind of a newbee to all of this downloaded the zip file twice and extracted it but odin does not fine the file CWMRecovery_DJ05_DL09_RED.tar.md5 is there something i am missing
any help would be greatly app..
I just flashed and then rebooted, now im stuck on samsung? How long is it supposed to be up there for :P
Edit: Nvm, took longer than normal, now im waiting on verizon :D
you cant use that for the leak jt is working on a red one now. there is a green new cwm that we need to use for now.
Dont extract the file, leave it as it then hit the PDA button
Market is buggy
I am having the same issues DCULLEN stated... Android Market is old version. I have downloaded some standard apps... i.e Google Maps, Quadrant, Gmail, Beautiful Weather... they all work. However, Kindle for Android and AppBrain wont download or install. You click on them and it says "item will be downloaded" and you see the little download icon in toolbar then it disappears and nothing happens. Rinse and repeat to no avail. This is a pretty slick update and I understand it is a leak, but if the market is going to be broken and haphazard like it is for me I am probably going to revert back. *sigh*
Status
Ruhanis
