Leaked DL30 Froyo Build Available NOW! (Includes Full Instructions: Updated 2/5)
Status
Not open for further replies.
Can someone please post a tutorial on how to flash this step by step from stock DL09 w/root. To official leak? I am a total noob and certainly would appreciate it. The furthest ive gone is flashing back to Stock DL09 W/Odin and rooting. Thanks in advance to adrenalyne, droidxcon or Cory. Whoever decides to make noob friendly. P.s I dont have voodoo and have no idea what CWM is or if we need it.
You'll flash this just like any other zip file in CWM Recovery. Follow my instructions in my last post.
Reactions: sahmad88
getting audio popping when playing music but gps so far is really good dont know about battery life yet be seems good
Update from jt:
"For anyone flashing this rom, do not use wifi tether unless you are paying for it. There is apparently a new snooping mechanism built in along with the kernel. I would recommend to either sign up for service, or wait for someone to publish a workaround."
Reactions: KG II
Uh...how long should the first boot take after install?
SHEW...never mind...just finished booting. For others after me, first boot for me (stuck at Verizon Screen) took at least 4 minutes.
That'll happen any time you flash a new ROM/kernel/clear dalvik cache.
Standby guys. Just got it installed. I am doing 12 things at once, but I promise to update the first post with a more detailed explanation of the following:
1) Flash CW Red with ODIN. As soon as it's done do a battery pull.
2) Boot into red buy holding the Volume up/down keys & power button. Let go over power button after second Samsung logo.
3) You should now be in red.
4) Navigate CW red and use it to remove Voodoo if installed.
5) Then use it to install the DL30 update renamed to update.zip.
You can get the update.zip on your SD card using reader vs. plugging into computer.
There's some clues. Unfo
did this happen to anyone else? my appbrain app list got removed... completely, it now only shows what I have installed on this new rom
if you enable usb debugging you can connect the SD card to your pc
Yeah... I was just passing on what I was seeing in the other forum.. Just in case some posters were getting the same results.. Trying to be helpful.
Thanks for your help.:)
Cory, Thanks Im gonna download adrenalyne odin CWM file then paste renamed dl30 zip to root of sd card, boot into newly loaded CWM and push update.zip. Reboot and voila I should be DL30 aka Froyo. Am I missing anything? I dont have voodoo or any lagfix at the moment. Thanks again
Nevermind. I decided to jump right in and install it. It worked. Thanks all.
no prob, just trying to be helpful as well =)
I also saw it install as a cdrom at first and freaked me out, then I remembered to enable usb debugging
methinks i'll be waiting a bit for the chaff to clear, and then wait even longer until the first super clean version comes out.
i like the bloat-free life and see no reason to go back to it.
Initial observations:
If you don't have it yet, remain calm. From what I can tell there are no major differences to get excited about. Performance or otherwise.
GrandOsand. That is correct. Let me know how it goes. It will be helpful for me as I update the procedure.
it's not too bad so far, and the search is google and not bing! so far the changes I see, I'm liking, so definitely worth it to at least give it a shot
*edit* haha wow, just completely contradicted you Cory... I still think it's worth it to give it a shot tho, can't hurt =)
Yeah you're right about the black bar and Google search, but that is all I'm seeing at the moment. Everyone should do this, but don't worry if you can figure out. We'll get a procedure up for you.
Status
ecomranx04
