LED Pulse notification light not working
isaac991
4
Hi everyone Im new here but as you can see in the title im having a hard time figuring out what is wrong with my Nexus 4 notification light. Ever since i got it (yesterday) I havent seen turn on at all, let alone work for notifications. The only time ive seen it on was using third party apps from the play store like this one called led tester and Ive looked everywhere online for an answer but all ive found so far are threads that are kind of vague in terms of answers so I dont really know what to do. I even called google but all they did was send me an email explaining notifications on Android but nothing really about the notifiaction light itself, so does anyone have an answer or a fix to this? And if it helps ive already tried a factory reset and my phone is not connected to a carrier (yet), so yeah.
Did you go to Settings- Display- and check Pulse notification light?
Almost no apps use the notification light directly. You need a third party app like Liteflow to enable the light in most cases.
and is that true? If it is then it doesnt really seem cool to put in the led if its not gonna correspond with the stock apps
As someone already said, You need to download Light Flow from GP and everything will be allright.
Stock Android does almost nothing interesting by itself, by design you need to add 3rd party apps to really take advantage of all the bells and whistles.
I am a target to that as well. i have checked the pulse notification light in the settings and also tried to turn on the device in safe mode as suggested on a blog. Nothing seems to work. Is this due to an application or is this due to a device gliche? Do let me know
that's not true in my experience.
i don't have Liteflow installed and plenty of my apps using the notification light - Whatsapp, Kik, Facebook messenger to name just three.
Techman
