lg g2 t mobile lollipop camera problem
Jul 28, 2015
11
I bought an lg g2 two days ago. Second hand. Came updated to lollipop. Camera is not at all optically image stabilized. V. Bad pics plz help. Will they get better in next updates and will the next updates even come. Other than cam issue Everythings pretty awesomee
Is the device updated with stock 5.x (Lollipop) or custom ROM (Cyanogenmod)? If it's stock, then quality should be as good as stock gets considering hardware. So I would suggest going into system settings > applications > camera > clear cache.
If it's a custom ROM then you won't have the quality of stock without installing a modded camera app to take advantage of the propriety software on the LG G2.
Adamsapple
