LG G3 Anyone happy with Lollipop?
Huh
My internal storage has 18.40 GB free and the SD card is almost completely empty (29.12 GB free out of 29.16). I downloaded OS monitor and now see the CPU gets up to 80% usage without anything open at times, and I'm not entirely sure why yet. I just disabled/uninstalled a few apps and force stopped a few others to see if that will help at all.
Also worth noting, I noticed the Tmobile My Account app using up to 40% of the CPU at times, with the battery going over 100 degrees F. So, I turned that one off as much as it would allow without being rooted and I haven't seen it come back on in the last few mins. The battery heat is finally dropping now, back down to 93 degrees, so maybe that app was just a mega CPU drain.
I have around 1GB, or a little more, free for RAM.
Besides the random apps I have stopped, I think it might also be the excessive searching for signals that is causing things to really drain the battery. I've been at work for 2 hours and have dropped 50% in battery already.
In the meantime, I bought a new, longer charger cable to hold me over until this is fixed. :) Thank you for all the suggestions, I really appreciate it and will continue to monitor more closely from now on.
You provided good information! I'm also on T-Mobile. At idle - my battery temps have been around 30c/86f today. CPU usage bounces between 15 and 30% and will spike at 50% occasionally, but doesn't stay there for more than an instant. This is only one data point - but we are both on the same carrier.
One more thing you might if you want to verify the searching for networks is churning battery - turn on airplane mode when you're at work for the first hour or so (if not too inconvenient) and see if the battery still drops.
My T-Mobile account info also spikes up on days - CPU usage, and I've stopped it. You may want to open My Account and turn off metrics collection. It likely won't make a much of a difference but every bit helps.
i don't hate it but i don't love it either. the early lag issues i had cleared up but it still overheats with the slightest provocation, charging is sometimes slow, battery life took a nose dive, and google now has a mind of its own.
My note 4 still over heat what should I do??
Galaxy Note4
Wow I've experienced non of those issues except battery drain and heating.... Fixed both with an app called lux. It was my screen auto brightness problem my screen wouldn't dim like it should, lux fixed those two issues... As for the keyboard auto correct.. Is horrible.. But thankfully not my issue... Since I'm a SwiftKey fan. With these two apps and turning off of the stick apps I don't use... My G3 rocks, on t-mobile network..
sent from LGG3 with lollipop
annahernandez51
