LG G3: AT&T
So for those of us who have been lucky enough to get the phone already, has anyone been able to confirm whether qi wireless charging works? I've heard conflicting reports.
Por que?
Sent from my LG-D800 using Tapatalk
Not liking the LCD display compared to the amoled on my note 3. Also I prefer touchwiz😀
App compatibility is better on my note 3.
There are more accessories available for the Note 3.
Posted from my galaxy note 3
re: LG G3 First impressions
Usually takes a bit to get used to it. I've only used nexus, HTC and Samsung devices in the past.
That could be it. I'll keep it for a while anyway.
Not out of the box
Seriously all you need is a different battery cover.
Guess I shouldn't be so harsh. All the OEMs sold out yesterday and the only one that's left is the Silk white for $148. That's to much for a battery cover imo. There's aftermarkets (that look almost the same) for 1/15th the cost but I wouldn't trust em. Last thing you want is the back of your phone melting while playing Order&Chaos.
I think that $148 was a screw up. About two below that I found the exact same white Verizon cover at the $45 price.
http://m.ebay.com/itm/151340377228?nav=SEARCH
Nope, they had every color every US carrier version for $45. Then quickly the non carrier branded devices sold out, white is the last one left so he bumped the price. I mean, really who the hell wants Verizons ugly logo. If you're on Verizon you wont notice a difference except wireless charging, but honestly that **** ruins phones lol.
signal is little weak when compared to Lumia 1020 and Nexus 5 which i used an can confirm this while i commute to work passing through semi tunnel and call got disconneted this never happened in Lumia but happened couple of times on Nexus
As a g2 owner,I would totally miss those back buttons, how is the signal strength vs your previous phone?
Can anyone confirm all you need is a change of cover and QI wireless will work? It's not the first time AT&T would have prevented this is why I'm so curious. I won't buy this phone without it, I'll just wait for MOTO X2 or keep windows phone. Thanks in advance.
MicroSD and G3
Hello
i am having an issue with micro sd card in my ATT LG G3 , when i popped in the sdcard for the first time all the content from the card showed and phone was still not active with ATT network at the time but ever since the SIM was activated the phone strangely doesnt recognize the sdcard content not shows the file system, does any one have the same issue with sd card? any help will be appreciated. thanks
I'm pretty sure the folks at XDA have confirmed this. The tricky part for me has been finding one to order online. Nothing so far.
Re: LG G3: AT&T
you have to make sure to buy the back with the contacts spread apart instead of all right close to eachother. Needs to match exactly the back of the AT&T contacts.
Just back from ATT got LG g3 black and watch.I also wanted the circle case but had none.Also I found out as I didnt read the fine print you can ONLY get one item on the half off LG deal not 2.
lphilpot
