LG G3: AT&T
Yeah- I need to know this too. My first time with a carrier-branded phone...paid full price. I'll be damned if I'll have creepy twerp Zuckerburg's sucking software spying on me.
Re: Problems with my at&t G3
"Your entire critique is about a setup issue? I too came from the g2,and loved it. You would be hard pressed not to the improvements of the g3 over the g3. Setting your phone up can take some adjustment time and can be frustrating."
Talking to me?
If you have an ATT branded G3 with carrier IQ, the last thing you need to be worried about is Zuckerberg...
Hi. We recommend uninstalling and re-installing PC Suite to see if this resolves your issue. Let me know if this works. ^DT
Hi, thanks for the reply. I reinstalled the suite with no success. Also, I dragged and dropped my music into the music folder and it shows up as "No Files". It is not a setup problem like somebody implied. I am doing exactly like my previous phones in terms as moving files into the new phone.
Looks really cool - thanks for the video.
How do I get to use that clock with he circle case when I don't see it in any of the stock widgets
Hi
Question how do I set up in the lock screen in order to see the weather effects and weather when I turn on my phone on lock screen.. I have the weather option clicked on under the lock screen option.. Also when you use the circle case ive noticed in the video of the lg g3 with the circle case that it shows a fancy clock in the ring.. I do not see this clock widget in any of the lg g3 default widgets ..
Hi
Hi
It should automatically work. Also make sure you have circle view activated in settings. If you take a magnet and position it towards the upper mid left side, it will activate it.
Talking to me?
Yes,try to use the quote button,as it let's you know who the poster is replying to. Your entire commentary was about transferring music,when at worst you could just take the sd card and move folders of music over with one click. That one thing is a huge improvement of the g3 vs g2.
Sent from my LG-D850 using Tapatalk
OK, question. I cannot load the Amazon mobile app. "Device not supported ". ,Is this another ATT monkey business? Anyone have Amazon mobile app loaded?
Sent from my LG-D850 using AC Forums mobile app
I believe it is AT&T monkey business. I've read that other carriers had it preinstalled. I'm on AT&T and had to load Amazon app through the Amazon app store.
I can't even manually get it from the Play store. Get message Device Not Supported!
I was getting the same thing but I'm on Sprint. The way I loaded it was to go to my browser and google ' Amazon appstore download' and DL that. Then, go to System Settings, Security, and click Unknown sources. Then go to the apk that you downloaded in your download folder in your internal storage and run it. Once installed, open Amazon appstore and download the Amazon app from there. You should be good to go!
Duncan posted this somewhere on some thread so credit goes to him for this. :)
I can't even manually get it from the Play store. Get message Device Not Supported! My Gord, ATT SUCKS!!!!
It's not AT&T. Amazon doesn't have this screen resolution listed. So have to sideload it until amazon updates their supported devices.
Hi quick question is it best to try to move most apps whenever you have the chance to the sd card rather than to the phone memory .. Any benefits to this .. Today I tried moving instagram and fb messenger to the sd card from phone memory and when I tried opening those apps they froze where I had to remove the battery . After I removed the battery they started working fine .. Any benefits into moving apps to sd card ?? or should I try to leave all the apps on phone memory ..
so why is it when I moved instagram and messenger to sd n I clicked to open these apps my screen went black and it froze and I had to take battery out.. SO your saying I should keep all aps in internal memory.. I did swith from dalvick to art as im running art which seems smoother n no lag at all
thanks
Moving large apps to SD frees space on the internal memory, but I don't see any reason as you won't have 32gb worth of apps on your phone. Just keep pics, music and movies on a larger micro SD card.
well maybe its because im running art but whenever I move a app back n fourth and I try opening it up it sorta freezes my phone where I have to pull the battery .. funny that I move instagram and messenger back to internal memory but in the app list it still shows on apps on sd but its actually moved to internal
View attachment AmazonApps-release.apk
Try this, though you will need root to install.
The Burg0964
