LG G3 Cases
Dodo Case
Just got my Dodocase version of Google Cardboard. I am officially excited about VR. Especially when it comes to my Xbox One. I mean it's not as bad as I thought. I can only imagine what it will look like in two years.
Re: Dodo Case
Do a search for Google Cardboard and you'll see it as a heads up display type phone holder device. Pretty slick looking, haven't seen reviews though. OP post pics and let us know what you think!
Re: Dodo Case
I am so curious about this but need to try it out in person before committing to buy.
I have a general dislike for all cases, but the quick circle case is pretty special. The case has a pretty premium feel to it, isn't quite as slippery as the original back cover, and the QI charging built in is delightful.
Sent from my VS985 4G using AC Forums mobile app
I put a Skinomi carbon fiber skin on recently. Looks great and doesn't cause any problems with any of my other cases. By itself it's still protective along with my iloome tempered glass screen protector.
Here are some photos:
Here with my favorite case, the Platinum from Best Buy:
Here with the Fintie circle case:
Here with the Slimpack case:
Re: Carholder for the G3
I've been using this since my GS3 with ZeroLemon battery, works great! Even better with a rubbery type case. I now have an Otterbox Commuter case on my G3 which is very slippery, it stays on the mount but does tilt and slide often. Only fell off on a few unnoticed potholes...
The Original iMagnet Cradle-less Universal Car Phone Windshield Das... http://www.amazon.com/dp/B008IOQ3K6...ag=hawk-future-20&ascsubtag=UUacUvbUpU3839349
You know, I've always wanted one and this looks nice.
Tired of my phone falling on the car floor all the time lol.
Re: LG G3 Wireless charging WITHOUT awkward circle case
Just got the news that the seller has shipped my order. Man this is sloooow.
Well urrl, you were right. Just got mine last night. Installed on my wife's and my phones and are working great. Only problem I had was when I peel the cut-out of the tape/backing the tape stuck to the backing and not the cut-out. I put the cut-out back and used scissors to trim to the cut-out. Then peels the back and got the tape on the cut-out. The rest of the installation was easy. There is an installation video at https://www.youtube.com/watch?v=B3J3iOH1orY&feature=youtu.be
Here is the link to the part
Factory Direct Wholesale QI wireless charging + NFC IC chip for LG G3 CASE D855 D830,D851 F400L,F400K,F400S support-in Phone Bags & Cases from Electronics on Aliexpress.com
Here is a link to the Qi charger I am using, I bought 4. One has an issue with the usb port and is being replaced the other 3 are working. Not sure how durable they are but the price was right. I did have a problem with them cutting in and out but it turned out to be the power adapter I bought. When I changed the adapter they worked fine.
Best Price! Magic Portable Qi Q5 Wireless Charger Pad For Nokia Lumia 920 & HTC & Nexus 4 5-in Chargers & Docks from Electronics on Aliexpress.com
Thanks so much! I ordered two chargers. It's a real shame LG did not equip the G3 with these from the beginning.
Actually I think that was a carrier choice. More money for them to get you to spend $$$ for a new back or case. Wish Verizon would have included it like they did on the G2. Oh well, have mine now. :-)
Anyone have the Otterbox Symmetry case?? Just wanted to know how snug the fit is. While I love my Slim Armor from Spigen, the fit is pretty flimsy. I dropped it (from 14 feet!!) and the case came off right away on impact. Protected it, yes but had I been moving the phone would have taken a beating once the case flies off. So I need the case to stay on even after impact so tight/very snug fit is what I'm looking for! Any other cases that have a tight snug fit are welcomed as well.
rose1988
