LG G3 Cases
Re: Dodo Case
This is the kit. With the resolution of the screen some if the apps are amazing. Like the gallery. Others probably don't run at this resolution so they just look good. YouTube is time a photo sphere with 3-d like viewing.
My point with this was that with this high res screen how exiting thus might be. And I can see why they will probably have true 4k resolution on these small screens.
Re: Best case ever IMO
I'm sorry, but I would never buy such bulky case for my g3
Posted with the speed of my G3
Re: LG G3 Wireless charging WITHOUT awkward circle case
AT&T. Man, concern for customer, even common sense issues like this, is negligible. Profits, on the other hand, are paramount and override virtually any other concerns.
Disable the Qi that the manufacturer equipped it with, then stick PMA capability on it, then provide only one expensive wonky accessory that will allow even PMA to function. Way to go.
I'm heading to the HTC M9 as soon as it comes out. At least HTC will sell you a phone directly without any butchery by ATT or Verizon.
So far as I can tell the Cardboard app and this viewer allow you to use your phone for stereoscopic viewing of certain subject matter. That's very good, but I would never have guessed what it was from the name. Only when I looked it up did I realise what it was all about.
Edit. OP: Am I wrong, can you view pretty much anything and get some sort of 3D effect?
Sorry but I have to disagree. :)
IMO this the best case ever!
Design. I love the clear back.
Build & Quality. It's doesn't feel cheap.
Just got my verus aluminum iron shield and a tempered glass protector and I have never been so happy with a case. Great quality hands down
Dude! I have the same exact setup.. I love it. Bought it from Amazon. My only gripe is the aluminum frame makes it want to slip out of my hand. Luckily not yet..
LG G3 Case, Spigen® [AIR CUSHION] [+Screen Shield] LG G3 Case Bumper ULTRA HYBRID Series [Metal Slate] Scratch Resistant Bumper Case with Clear Back Panel for LG G3 (2014) - ECO-Friendly Package - Metal Slate (SGP10989)
Is there an AT&T version? I didn't see one...
Not yet but hopefully soon. I sent the manufacturer who produced the Qi sticker chips with a AT&T LG G3 for them to do research. Hopefully they'll get some results and make some PMA chips. They'll let me know ASAP before anyone else. I've bought over 500 Qi chips from them so they know I'll be buying a bunch of PMA chips
You can get the latest updates at LG G3 PMA Wireless Charging Sticker Chip | ATT LG G3 | XDA Forum
Re: Carholder for the G3
I got tired of suction mounts that come off, windshield mounts that bounce with the road. I discovered Mountek that use the CD player. They work well. I personally like the magnetic mounts. The metal plate fits between the phone and the case. One warning, if you use qui charger take the metal plate out first.
Amazon link: http://www.amazon.com/s/?ie=UTF8&ke...ag=hawk-future-20&ascsubtag=UUacUvbUpU3848392
Me too. Been using the Mountek in the CD slot. Very good . Holds steady. Very easy to remove and reinstall. Second or two.
@ Gvndeb60
I ordered one since the wireless sticker thingy did not work for me.
Nice find. Thanks
OK guys here you go. Looks great. If it is a cheap Chinese knock off and not an official European one, it is a good knock off. Fits great and looks perfect. I have a snap on Spigen ultra thin case and that still fits so it does not appear to be thicker, it is hard to tell just by looking.
I was looking at this case for a while, but a lot of people have complained that the metal band interferes with signal big time. After testing, it was found that with this case on it degrades the signal by 50% or more. I don't think I am willing to take that big of a hit even though this is one of the nicer looking cases out there for this phone.
Have any links to does test?
http://www.amazon.com/Ballistic-Jew...ag=hawk-future-20&ascsubtag=UUacUvbUpU3848776
This is the case I'm currently using. I absolutely love it. I previously used the spigen slim armor but I found this case to be superior. Absolutely great drop protection. Rated for 6 feet in fact. Really cool pockets of air on the corners to absorb impact. And the design is fantastic. Clear and see through all around. I love that the back and sides are still thin, so you have the protection of an Otterbox without the bulk. Can't recommend enough. I paid over $20 for this case. At the current price of $11 it's a steal.
Wow, that actually looks really nice. Do they have it for other phones too?
Sent from my Galaxy S4 running SlimKat 4.4.4
I put a Skinomi carbon fiber skin on recently. Looks great and doesn't cause any problems with any of my other cases. By itself it's still protective along with my iloome tempered glass screen protector.
how do you like that carbon fiber skin? That looks pretty good. I might consider it.
Does anyone know where to get a custom case made with my own picture to be used on it?
mostafamu
