LG G3 - WiFi and Bluetooth won't turn on, why?
  • Start date Start date
Re: LG G3 - WiFi and Bluetooth won't turn on
Hi guys,
I had the same problem. After i had searched over the internet, i found out it might be a hardware problem.
The main problem is that the LG G3 wants to open bluetooth andwifi at the same time.
How to fix it?
Reboot your phone, and press volume down until your phone is in safe mode.
Now go to settings and turn off bluetooth.
Turn on your wifi.
Turn off safety mode and reboot your phone.
Cheers.
Regards,
Jan
YOU ARE A GOD ! It works ! <3
Try this..go to settings > general > storage > cached data > yes then restart
Hopefully it helps..thanks
Hi guys,
How to fix it?
Turn on your wifi.
Cheers.
Regards,
Jan
Wow... This worked for me. I was all ready to get a new phone.
UPDATE:
Worked perfectly for a good 5 minutes then it's completely dead now. Even after changing batteries/waiting, etc. Here I come, Zenfone!
I had the same problem but Bluetooth is working perfectly if I start it from the "Bluetooth " button on the notification panel and not from the Bluetooth button from the setting panel ,please try ,no need to make a factory reset
Hi All,
The WiFi and Bluetooth capabilities on my LG G3 phone randomly stopped working yesterday and both connections won't turn on. I have tried to enable both connections, but the phone either lags out or does not recognize the command. This isn't the problem of the LG G3 not recognizing networks or finding Bluetooth devices, but both connections won't even enable.
Has anyone had this issue and if so, how did you resolve it? I've tried factory resetting and that did not remove the issue at all.
Thank you!
Hi All,
Thank you!
I have had same problem, 2 months ago my phone's wifi and bluetooth stopped. My phone 3 years old, so battery was old. Often there was no problem on modem, camera, cpu or other things, but sometimes usb hasn't worked with modem, while wifi-bluetooth not working. And last week, phone started to bootloop.
You can think that, my phone is dead, but only the battery. Battery percentage only shows the voltage of battery, but phone uses in power ic lots of amperes which can drop dead battery's voltage suddenly low. Low battery under load offers low voltage. So PM ic can't give enough voltage to wifi chip or modem, especially wifi ic. If you can stop wifi applications, phone not turn off or bootloop. But batterie's death is on way. So bootloop is inevitable.
My opinion on LG G3 motherboard problems before all recommendations is changing battery with a good battery, and wait 1-2 days for battery maturation. Than probably all problems will go. Don't run a factory reset or ic reballing before changing battery.
Make it be easy.
byronsss
