LG G3 Wireless Qi charging
I ordered the same one from Verizon, and it works fine on my LG Qi charging pad. Now the back of the packaging does say, that it also works with powermat charge
So glad to hear that! I have a pretty janky Lerway charger and was wondering if it might not be the issue. Ozz, if you're able to, could you post the case model# you received from VZW? Also, were you using the older LG circular Qi charger or the newer one marketed for the G3?
Oh, forgot to mention I'm using the TMO ver (D851), and in case(pun) anyone is wondering, the case shipped by VZW is not carrier branded.
The Verizon case model# lgvs985wrlcase, and I'm using the LG WCP-300 wireless charging pad. I'm using it on a Sprint LG G3.
I received my case today and it DOES NOT work with my Qi RavPower Charger. Mine also says "Compatible with POWERMAT Wireless Charging Product". It says nothing about Qi on the packing.
Does it look like there is a way to separate the front flap from the back so you can use the charging capability with any case? Or will there be an opening left on the side?
Sent from Frope's sweet G3.
Thanks for the info! I've got the same case, so going to give an LG charger a shot.
I bought the VZW wireless charging circle case and peeled the charging pad out of it and then peeled the NFC pad out of the original batter cover and then placed the wireless charging/nfc pad from the circle case in to the standard battery cover. Works great and works with all phone cases.
My VZW charges on QI pads.
I got the quick circle wireless charging case a couple days ago and it works fine on the zens qi charger. It is really finicky about placement but it works.
I purchased 5 Qi/NFC wireless charging stickers from China. Waiting for it to arrive to see if it works. Based on their YouTube video that they showed me, it does. If I was to setup a group buy (I made a thread on XDA forums - FEELER: Possible Group Buy Qi/NFC Sticker | LG G3 | XDA Forum), would anyone be interested in purchasing? I'm trying to get a feeler and I don't want to be stuck with 100 of these stickers and spend almost $1000 if no one is interested.
For you At&t users. I bit the bullet and picked up the power Matt circle case. In store it cost me less than $13.
Sent from my LG-D850 using AC Forums mobile app
I ripped off the flap from the AT&T PMA Quick Circle case. I've been using it for almost two weeks, and it works fine. There is an opening on the left side, but there is no opening into the back of the phone. Its basically a slim hard shell case. Slight profile and the PMA wireless charging works just fine.
Sent from my LG-D850 using Tapatalk
There's been some reports of some people ordering and not getting the cover that was pictured. They either got the cover with NFC pins only or no sticker at all and just the cover.
That just happened to me. Picture showed 4 pins. Received it today and its just a plain cover with no sticker. The day after I ordered their listing shows they changed the picture which now shows just a plain cover. I'm awaiting their reply before reporting to eBay.
Gold LG G3 D850 D851 D855 VS985 LS990 Back Rear Cover Battery Door Housing | eBay
Has anyone else been able to get the case for this price? For that much, I'd buy one, pull out the coil, and put it in my current back cover. But I've only seen the case for $60.
Not sure. I asked if I would get 10% discount. He scanned it and it was only 12 something.
It's made by a chinese manufacturer. It's available from Aliexpress but I've been in contact with the seller/manufacturer and they are sold out but was told that if I place an order for 100, they'll have it for me and I would have it within 3-5 days. I'm just waiting for their confirmation.
I made that thread to get a feeler to see if people are interested and it seems I'm getting a lot of interested.
Because the stickers you referenced are Qi and I need PMA (AT&T phone).
You can try and call your local store. See if they have any in Stock and what they scan for sale as price.
djdjjkzzz
