LG G4: Phone in vibrate mode, after phone call, automatically is back w/sound..?
  • Start date Start date
A
AC Question
LG G4: Phone in vibrate mode, after phone call, automatically is back w/sound...
I have my phone on vibrate when I'm at work, if I'm to make a phone call, it automatically puts it back with the sound active. I have to manually go and turn it back to vibrate. Pure frustration!
Bump. This is super annoying. I already checked every setting..points to marshmallow update because everything else seems fine
Re: LG G4: Phone in vibrate mode, after phone call, automatically is back w/sound...
Have you tried to clear your cache partition since updating? It's generally a good idea to clear your cache and/or do a factory data reset after a major software update.
I think I figured it out. This is due to the "SoundAbout" app. I turned it off and it was fine after I called/received phone calls. My phone was still on vibrate:)
I'm having this problem too... Volume turning on after a call Is either made or received when phone is in vibrate mode. Any help? I've tried everything I can find to try and fix it except hard reset which I don't want to do.
Vector
