LG G4 Wireless Qi Charging
Lol.....it's the black leather. ....the A C app kept telling me I couldn't repost, so I kept trying, and then realized it posted like 3 times.....lol
I bought a Qi nfc sticker on Amazon and so far it's working fine.
Did you have any trouble getting yours to work? I bought a pad that looks just like that installed it and am getting nothing, I've tried moving it 4 or 5 times and still nothing. I have a H815 and wasn't sure if there was a setting that needed to be enabled or not. I made sure that the contacts are hitting and am getting nothing at all.
The contacts are not fitting snugly. I had to place 2 little pieces of electrical tape under each pad under the contacts area and then it connects reliably. There just isn't enough constant pressure without raising up the sticker contacts a bit. A few of us have had this happen. Give it a try.
I snagged a Quick Circle case and it works with Qi on my AT&T G4. There were some concerns about it being PMA only, this is not true. Qi working fine!
That's what I also needed to do too. Works like a charm now.
That is very good news for the many of AT&T owners out there.
I would create a new thread, this information may get lost in this thread.
Again, thanks for posting!
Nice. Maybe it does both and just depends on which back you get?
Agreed, though I hope I can find someone to Frankenstein it for me.
I bought the Same style sticker and am having no luck with my 2 Qi chargers : 1 flat the other a slanted stand.
One thing I noticed on the Quick Circle case was that Both connectors are on a Small Raised Surface : a little bump where the 2 gold chargers should lay on. Otherwise, the arched back won't allow for a "contact" or connection (?). The Leather cases only have the Raised Bump on the middle left side. The top right is a flat surface. I'm guessing the NFC is the 2 gold connectors in the middle left and the 2 gold connectors we Need are on the upper right (as looking at the back plate.) but it's a FLAT surface basically leaving us without Qi charging for NOW. As more OEM back plates become available I'll be looking for that Raised spot on the upper right side.
Also ... are there 4 connectors on the middle left with 2 of them covered???
ANY suggestions are helpful.
Thanks,
liveTexas
Thanks,
liveTexas
I tried several times and could not get the Qi charging to work using my sticker. I just saw xgman's post where we need to raise the contact out a little to get the charging to work. I stuck a small folded piece of paper under the contacts and everything works fine now.
LilPandaBear1105
