LG G4 Wireless Qi Charging
Didn't think going through a case mattered except if it charged at all.
Here's a Screenshot. 19% to 48% in an hour. This was using the CHOETECH circle case
Bummer that I couldn't get any sticker hacks for my H818 LG G4 since it's a dual sim phone and the 2nd sim slot took the place of the wireless charger pins. Wired charging forever on this phone ;(
I went with the yootech sticker and charger also. Installation was easy and it charges the phone no problem. It's slower than wired but fast enough. Positioning on the charger base is a little sensitive but only takes a few seconds to get it correct. (The yootech charger goes from green to blue when properly positioned). The phone also now charges on my tylt stand.
So I finally got around to adding one of the main features I missed most from my previous phone. Hazzah!
I ordered the Yootech sticker, as well as one of the Yootech round chargers (since my wife won't seem to give me back the other one I used to use.
Instillation was pretty easy. The hardest part was scraping off the existing nfc sticker before adding the charging sticker. Other than that, it works like a charm. Charges faster than I would have thought too (although obviously not as fast as plugged in.)
The Yootech round charger is kind of nice too. It has a raised, rubber ring around the outside which holds the phone nicely compared to a completely flat charging base, which the phone tends to rock/wobble on if nudged.
I just ordered the yootech smart circle case and the triangular shaped charger. Looking forward to it. My cruzerlite case is starting to loosen up and slipping off on the corner when it gets caught.
Have the original Qi/NFC LG G4 flipcases and the Clear-Qi-Wireless-Fast-Charger-Charging-Pad-Mat-For-Samsung-LG-iPhone-HTC-Moto charging pad from ebay. My flipcase didn't do a thing from the start. Have ordered new stickers to see if that would bring a solution. Today I put some folded paper underneath the contacts and it charged my phone from 17% to 44% (at least that was it at when I noticed the charging pad wasn't lit anymore). During the day I have added some painters masking tape underneath the contacts but it still after 4 layers is troublesome charging. It came with several correction to about 90% but it keeps disconnecting from the Qi pad.
Maybe the rectangular charging pad would work better. My wife took the car with the Qi car holder (has 3 coils) so unable to test if that will work better than the pad.
So far pretty frustrated with my purchases..
John
I have had great success with a back cover I ordered from here:
LG G4 Metallic Grey Back Cover Door with NFC QI Enabled
It has the sticker already pre-installled and fits like a glove.
Both NFC and wireless charging work flawlessly!
The wireless charging also still works with a Diztronic TPU case and my Seidio Dilex Pro case.
The price is pretty competitive as well.
Yep running it on my AT&T LG-H10 (updated version after boot-loop fiasco). At first it didn't seem to work but after removing and replacing the back a time or two the contacts seemed to come together. I got a cheap $4 wireless puck from Wish and it works fine. That is if I take the outside layer of my 2 layer case off and position it just right on the puck.
That's weird, because the web page selling this sticker only promises compatibility with:
Compatible with:
-- Verizon VS986
-- T-mobile H811
-- Sprint LS991
-- US Cellular US991
-- H815​
Are you sure your phone where this works is a model H810?
liquidsnake757
