LG L34C Optimus Fuel - how do I root this phone
My Net10 LG L34C running Android 4.4 did in fact root with the string mentioned in this thread. Actually it failed once, but after a reboot I tried again, and it work and stuck.
I got it for free on a Kroger deal, and have no intention of using the cell radio. Wifi will do, so unlocking is not an issue.
What I would like to do is get a more up to date OS on it. Is there anything available, and does the fact that it is rooted help?
You would have to search for your device on XDA developers, if there is a dedicated forum for it then there are probably custom ROM's for it. And yes, being rooted helps.
ok. soo heres my deal. imulater says it finds no su. towelroot wont download and su says it needs su. where can i find it?
I have tried everything and I can't root my phone! So f*cking irritating!!! I've tried everything listed above and no luck! Anyone know what else I can do to be able to move **** to my sd card?? HELP!!!!!'
A factory reset will unroot your phone... however it will not reinstall bloatware.
I rooted an old lg l38c and deleted all google bloatware (google, play store, drive, etc) and realized i wanted play store. I tried a factory reset, and I was unrooted, but all bloatware was still gone. I fixed that by installing out of market apps and it works fine.
Will not work unless you have an internet connection. So we need a version of Towelroot of complete package or it is useless offline.
pratikkumarBB
