LG optimus g pro GPS question
TheyStoleMyName
429
I posted this in the LG section and a few ppl have this problem but now answer to what causes it.
My lgogp GPS will turn on automatically during a call. I did a hard reset and it went away. I updates the stock apps one by one to see if a certain app caused it but couldn't find it. It seems like a Google app is the issue. I also tried uninstalling all updates and disabling certain apps but it doesn't go away.
So do anyone experience this on a different brand phone?
from what ever phone I feel like using today.
I have also had this same problem. However after looking through AT&T's website for the LG Optimus G Pro, I found a way that helped my phone stop doing that, I suggest to try it out to see if it works for you.
Go to Settings > General > Location Access > Turn on "Access to my location" > Check Wi-fi & mobile network location > Uncheck GPS satellites > Turn off "Access to my location". I hope it helps someone.
I had same problem before.
Try this.
Do factory reset and when you sign up the google play app, quickly go to my apps and uncheck auto update.
Also, on google maps app, do not update..
Mine works now but i dont know how long it will go.
Good luck.
tinni99
