Liberty. 07 Is Up And Running!!!
Liberty ROM
I installed .07 last night and its working beautiful. I have the pay version of liberty. My question is...does it download the nightlies automatically for me or do I have to go in a manually check for daily updates?
You have to check manually.
Posting this here as it involves Liberty to an extent,
I go into Rom Manager(I rarely ever do) and downloaded Drew Garen's Broodcomb keyboard and install it. My phone boots back up to the lock screen which finally says Liberty .07(so does Setting clickie, about phone). But the keyboard is not under Language and Keyboard, instead I have two Gingerbread Keyboard entries w settings. See below
Can you take a snapshot of both?
What's the difference?
None, it's two Gingerbread keyboards,lol weird huh. I had steve lin's that I bought, and another with just the green android square icon that said Gingerbread keyboard but nothing about the one I tried getting from ROM Manager(not the Liberty toolbox one). So I deleted the green square icon one in Titanium and re-peated the attempt with the same results. Maybe I cant download things from cwm rom manager and intergrate them outside of the liberty toolbox. Or is that too far fetched?
Way too far fetched that it might actually work!!
I been using Swiftkey Beta (since I installed it to see if it will work in Liberty .07 for a member here) and so far it's ok. I just want to give it a full week of use to see if its worth it or not. So far I am ok with it, not happy like the stock keyboard, which one is the Steve Lin's keyboard? Market?
Im on 0.6 and in the Settings>Accounts>Tap any of the above services to add new account blah blah blah option, every time I tap on facebook or twitter (downloaded applications?) nothing happens. I need to sync my contacts so its pretty annoying. Anyone know if this is fixed on 0.7 or anyone even having this issue?
Root issues after flashing V0.7
Since I flashed Liberty GB V0.7, when I access Titanium Backup Pro, I get the message "Sorry, I could not acquire root priveleges. This application will *not* work! Please verify that your ROM is rooted & includes BusyBox, and try again.
I do show the Superuser icon, which is supposed to verify that you are rooted and I have Busy Box Installer Pro installed as well. Has anyone else experienced this issue or know what I need to do? I rely on Titanium for my apps backups!
I had the same problem with .04 Liberty.
Do this, it helped me:
Open Titanium Backup and on the bottom click on "Problems?" it should give you and option to install Busybox.
Alot of people are having this issue. Not sure what the fix is yet. I do not use facebook and I added twitter trough the app.
I prefer to post here to continue with this issue related to LBG .07:
"Can you use, in the Toolbox/Liberty Mods/Build Properties, use Call Ring Delay and Dalvik VM Heap?
I can open this options, set them to my liking but when it asks me to reboot and the phone is on again the settings are gone"
I found the solution to this settings and how to make them stick (Thanks Kilahimm!!):
Change this options and more by using the file editor in the toolbox. Go to build.prop settings and find and choose Call Ring Delay and change it to your liking (According to the help section in the ToolBox " This will make the phone rign faster when dialing is out, and according to Jrummy it will save battery. the default is 3000, I set mine at 700)
Dalvik VM Heap option is kind of tricky, USE AT YOUR OWN RISK.
PLEASE READ THIS LINK BEFORE MESSING WITH THIS SETTING:
Test: How changing the max amount of memory per VM Heap can effect your ROM (Cyanogen) ? Ryan Olson
I personally haven't mess with it, the default is 32mb however Liberty GB has you set at 48mb.
You can find all the definitions and answer to this settings to the Build Properties menu in the Toolbox if you hit the menu key and go to About/Help and then choose More Help.
Again MESS AND CHANGE THIS SETTINGS AT YOUR OWN RISK.
Make sure you use the option button to select save after you make any changes. (can't just use the back button to exit out)
jrummy says via twitter that .o8 should be dropping today. wooo were gettin closer to final
Sent from my DROIDX using Tapatalk
He just posted it MIGHT be delay...
Also according to Koveleski that blur icon will disappear in 0.8.
I tried jumping from v05 to v07 and it now says my version is v06. So I tried going from v06 to v07 but it still says I'm on v06. Am I missing something?
It's a known bug I've seen a couple of times in the forums.
I believe jerseyboy357 had the same issue. Care to chime in jersey?
"jrummy16: Fixed Droid 2 link and if you are on DX and have automatic updates installed the version number should be fixed after a reboot"
That quote came from an earlier post in this thread. For some it works, for some it doesnt. My fix was...
...once jrummy condensed the toolbox nightly menu to just listing .07, I re-installed that and everything was fine, .07 all around. Full reboot and I was good. It might be a bug per device or install because some have had no issues, and others have. Either way, today was not .08s day as its past midnight but he is still cranking on it as we speak in a update.zip format
zulancu2
