[LINK][GB] SkyRaider Zeus Preview [2.1 Hybrid][08/06/11] :-)
awesome rom no problems whats so ever so far. wish someone would figure out the voicemail problems though, but thats been the case with every rom
I keep hearing about voicemail issues but I never had any issue, what type of issue are you having?
i never get a voicemail notification i only get them when i reboot the phone then it pops up after i listen to the voicemails the vm icon stays on it wont go away
thats strange...
Have you ever tried to use google voice and then decide against it? even if you havent, try and dial *73 on your phone, that should reset this problem for you. then just to make extra sure, go into settings -call settings - make sure that 'voicemail service' is set to verizon' and 'voicemail settings' are set to 'my carrier' and *86.
let me know if any of this helps...
Reactions: panitsos
i did a restart on my phone and lost all my settings, is that normal?
lost my accounts saved on my phone; google, facebook, etc.
my data and apps saved but settings were lost. any idea? this would be a deal breaker if i have to rotate extra batteries and end up losing settings.
Def not normal... I haven't heard of that... I will look into it some more... hopefully someone else could chime in and help you out in the mean time
Excellent ROM. I'm using it with the stock kernel, as recommended by the dev himself. Hopefully, battery life will be exceptionally above 14-20hrs.
The only issue I've had so far is the screen graphic that pops up when I get a phone call. The animation graphic seems to be a bit glitchy at time.
I flashed this ROM to my TB and now it won't connect to the internet. No 4G, 3G or even 1x. What did I do wrong? Everything was working fine on CM7.
How does this compare to Monolith Theory ROM?
The only major differences are the dropdown notification bar that zeus uses and the fact that you can easily overclock Monolith as well as use quite a few custom mods that he and his team add to his candystore app.
I use 2x battery and wifi whenever I can, but I do believe that Zeus may have slightly better battery life, but its not enough to make me pick zeus over monolith. they are both great roms but I have had less problems with monolith
Hey ssethv i saw on that pic u posted that your battery icon looks just like the one from x2 battery but how did u change it to be that way?
Great ROM, reflashed after my initial issues, looked like an unclean install but has been working flawlessly.
If I could just get the camera that was in BAMF on this I would be a happy camper. I just miss the option of the panoramic pictures without the bloat of another icon/app. =]
I have the MR2 radio on it but am also curious if the 2.11 radio is better...
I'm running the 2.11 and SkyRaider now, first install have me no data, but I went back to the OTA MR2 then back to 2.11 and all is well. One small problem I found was if I was in CDMA/LTE Auto mode I only got 3G, so I used LTE OnOff to go to LTE mode and back the LTE Auto, and all was well.
Damn. This ROM sounds great, but I just don't like Sense. I haven't liked it since the good old HTC Hero. I wonder if Skyraider will be working on any AOSP ROMs...
pramanj96
