List of ROM's, Kernels & Themes
I have read in other locations that text and MMS messaging issues are usually DJ05 modem on a DL09 rom/kernel.
There may also be an incompatible feature of the Theme/ROM with the DL09 - Have you flashed the theme hax/fix?
No I haven't I'll try that. If I don't find it in Rom Manager, can I just get it from XDA?
whats the diffrence between supa clean and black mod
well lets see, "supa clean" doesnt exist. super clean is a ROM and black mod is a theme. if you are asking about Superdark, it is another debloated ROM. very similar to super clean in rom content, however superdark is prethemed, super clean has a stock feel.
ok because i got black mod in the rom manger? is it ok to flash roms and kernels like daily untill you find one that you like
You bet. I flash a new kernel every time I see a newer or test pop up for a trial run. Makes life interesting. I have encountered a couple of issues and I flash back to a kernel I have used without issue.
I actually have a folder on my sd card with subfolders holding different kernels.. when I want to try a rom/kernel combination I just load up what I want...
Reactions: afbar1114
and btw i think i ment blackhole.. so whats the diffrence between black whole and super clean.
oh!! ok. blackhole is a build your own rom you build in rom manager. you pick as much or as little as you want. you should give it a try. its a good way to figure out what does what in th rom.
thanks i am trying it out now...any pointers like will something not work like google maps, slacker, or my bank app?
I am running Blackhole v3.0 - I loaded up minimal with only what I wanted and cleared all bloatware.
Back up ROM, Back up your apps with Ti Backup and away you go..
You select what your want and it downloads, self installs, and all you have to do is clear your data and cache - and you can pick Ti Backup in the menus during your installation. It is similar to superclean .4.. Swype is included in Blackhole but not in super clean.
Try it - if ya don't like it Restore your ROM from before.
I have had no issues with it at all.. I did have to reinstall all the ringtones after I was done.. Installed ringtone app and in 10 minutes had everything I wanted..
You can easily add in any other apps from Rom Manager that you miss..
is the clear ur data before u install
everything is good so far seems a bit faster. i was able to get the facebook app with out tw. and my rm is around 180 too which i am happy about. i loaded all my apps back on with appbrain(has saved me more times then i can remember). but so far i am liking about to do a theme now
Qbaumildand
