List of ROM's, Kernels & Themes
everything is good so far seems a bit faster. i was able to get the facebook app with out tw. and my rm is around 180 too which i am happy about. i loaded all my apps back on with appbrain(has saved me more times then i can remember). but so far i am liking about to do a theme now
the only thing tw does for face book is sync up with contacts, you can still load and use the app.
Reactions: afbar1114
is it worth over clocking? i tried it once today and it seemed my phone got hot fast. but let me tell you it was fast
no i didnt. when i was using super clean and the super dark theme i had no ads. is there a way i can do this with the blackhole?
I would advise against it. I have been down that road and it does nothing but create headaches and frustration.
Overclocking makes your kernel a battery vampire... The heat you feel is the life being sucked out of of your battery and that heat is not so good on the hardware on the phone (to put it lightly)..
agreeded, the processor is what it is for a reason.
i flashed the circle d battery from xda and lost my power screen. when i hit the button it just restarts and thats it doesnt even shut down.
Which one did you flash? - there is one specific to DJ05 and another for DL09 -
DJ05
DL09
If you flashed the wrong one that may be the problem.
do they have one thats like stock the others seem to dark to me and the task bar is too dark i find something i like in one and some in the other.
What you are experiencing is a incompatibility issue between theme/ROM and what you flashed. You may have to go back to a ROM/Theme combination that works better together.
You can start with a theme that will be compatible with the ROM you have - and has the battery icon themed the way you like it.
You did do a nandroid backup with ROM Manager right? - That should take you back to where you started.
yea i did
yea i did
Perfect! I had the same issue with superclean .4... I was long pressing the power button and causing a reboot.. there is a fix to install Black Mod Enhanced Theme with the theme fix applied and that resolved the problem.
You can try that.. I know it is a darker theme but it has helped a few. I ended up switching over to Blackhole v3.0 with Black Mod - The ROMs are very similar.
Hope this helps.
does anyone know if there is away to kill the ads in the aps and all or is that part of a theme
what are you talking about
1. when i was using superclean with superdark no ads would show up. so i am woundering how to do this again.
2. thanks for helping me with this rom. i feel like this rom was ment for me because i chose what to put on it and what not to put on it like touchwiz. i am also happy because my ram is around 160-220 and doesnt go above 230 now so that makes me happy because less battery use..
dumpsterrentals85
