Llama - Who's Using It and Any Good Examples?
I want to setup Llama, so that whenever WiFi is NOT switched on, then 3G data should turn on every 20 mins for about 2-3 mins, to allow syncing of any emails/messages etc.
How to set this up ?
Thanks
The condition should be "when not connected to any wifi network" then turn on data and turn on and force sync.
Also, add the Queued event: after 2 minutes, turn off data and sync.
In advanced, set repeat every 20 minutes, and enable "don't allow if condition aren't met".
Regards,
Enviado desde mi GT-I9100 mediante Tapatalk
Has anyone been able to disable data on android 5.0 please? It doesn't seem to work for me :(
On settings, you have to enable "see apn/data in menu". If that doesn't work, try with the locale plugin Securesettings.
Great thread thanks.
I've been using llama (very basic stuff) for a few years but just downloaded it to new phone
Hi,
Anyone knows of it's possible to set slide unlock at home and patron unlock not at home.
I tried setting "disble screen lock after unlocking" (or something like that) when at "Home" which worked but then I couldn't get the phone to ever lock afterwards! Had to uninstall and start again
Query for you useful people…
I want my phone to remain on "Vibrate only"when I’m playing golf.
I don’t want to map entire course area and define that as Club as then Lllama will switch to silent if I drive past the far end of the course in my car when I’m on my way to supermarket!
Also the cell signal in area is weak , easily dropped so may switch to Loud thinking I’m in Unknown area.
An audible ringtone is a big no-no whilst playing golf.
So –
I have mapped just the car park and defined this as Club.
Then set Llama to “Enter Club > change profile to Vibrate and lock profile for 5 hours”
This works a treat. No Risk of phone going to loud.
But when it loses signal, then refinds it, Llama thinks I have entered Club area again and locks profile for a further 5 hours. So as I re-enter car park after my round of golf, my phone goes to vibrate for 5 hours *after* I’ve finished my round.
I assume there is some way to tell Llama not to repeat the profile locking for X hours after the initial lock, but don’t know how.
Thanks in advance
What that does is to disable the lookscreen, not even slide unlock...
So –
Thanks in advance
I am sure there are many, many ways to do it, but I would use a Llama variable as a flag...
Add to your event conditions "when Llama variable 'Variable 1 (or name it whatever you like)' has value of 0 (or whatever)".
Add to your event actions "Set 'Variable 1' to 1 (or whatever else as long as it's not 0)".
Then create a new event that resets 'Variable 1' to 0 sometime when you are sure you are not around the car park but before you are ready to go for the next round of golfin'. Everyday at midnight would probably do.
EDIT:
After creating this new event, immediately "test actions" or "run event actions" to set Variable 1 to 0. Otherwise, your "Golf - Vibrate" event will stop working.
Locking a profile is one of the features I don't use in Llama. It's too complicated for me.
I am sure it's very useful if I can take advantage of that! :)
EDIT:
Thanks buggydroid.
i've never used variables, as everything I get llama to do is very basic. I might snarl everything up if I over-reach myself...
I use the manual lock profile a lot so it's really no big deal for me to unlock it.
Llama makes us lazy!
It won't start on my phone, crashes at startup :\
In such a case, the developer suggests you email him the log file, which can be found in the /sdcard/Llama folder and should be named Llamalog.txt.
The dev's email you can get from the app's page in the Play Store
Does anyone know why an text is delayed send when i have a setup like this :
work > when leaving area > send text message
driving car > no area set
entering city that i want to send a second text > 2 texts are send ( the delayed one from work and the new one )
Anyone has a clue please?
How narrowly are your work and city areas defined? If your phone is not dissociating from the work cell tower until you get to the city, then the first event won't fire. Whenever possible, keep an eye on when the location change actually happens in Llama (I don't recommend you do this while driving; maybe have someone else drive or look at your phone if you're driving.)
They both have 4 cells , work has 8 hours learning time and city area has 4 cells 1 map location.. They are 45km removed from each other so i'm sure i'm connected to other cells.
what i have seen happening is that i don't have area selected at all in the tool , yet in recent i area .. ( work ) -_-
Cozbob
