location problem on websites
  • Start date Start date
A
AC Question
I am having problem with my location on my android. When I'm using the Internet app on a website like Walmart there is a store locator and when using that you have the option to type in your postal code or locate device automatically. Whenever I try to locate device automatically it says I am in Toronto with the same postal code every time which is wrong. But when I use the Google maps app it locates me fine.
Install GPS Status & Toolbox to see if your latitude and longitude are being read correctly. If they are, the website has a major problem. If they're not, your GPS has a problem. (The site appears to work - it locates my local Walmart store.)
KidColoringPage
