lock screen animated weather?
Yes, the factory data reset you would go to settings>scroll down to device>storage>factory data reset. Then if you want to do the system update make sure your phone is on wifi and charged to at least 35%. Then go to settings>scroll down to system>AT&T software update
O.K. So you're saying that a factory reset would wipe out all my data, and the ICS update, and return my phone to GB? :)
Yes, unmount and take out memory card and sim I say just to play it safe and yes, the phone I was using was the beats display phone so had Icecream sandwich, we reset and it didn't. Then I did the update. This is assuming your phone didn't have Icecream sandwich when you bought it? I am not aware if the new ones are shipping with it.
I bought it in Feb. at AT&T, and it had Gingerbread on it. I believe that it had Beats Audio already on it, but it was definitely GB 2.3.?. Thanks for all the info.:)
Do make sure you're backed up. You'll be able to recover your apps from the market or wherever you downloaded them from. Your contacts will be re-synched from Gmail. With a hard reset, you'll be setting up the phone from scratch, with the exception of regaining your stuff from the resynch.
Here's the answer i was looking for...The weather wiper works when the app on your home screen says SHOWERS, not when it says RAIN. A reset has everything working correctly.:D
Taylor Bag
