Lock Screen Help
Just the Samsung have auto brightness for AOD
Actually if you unselect auto brightness, you can also select your own brightness level. So Samsung indeed gives full control to select whatever brightness you want on AOD.
Yes , they are the Masters of AOD lol
Thanks for all your responses. I posted the problem via FEEDBACK. Hopefully it'll get fixed by the next update.
Also, since there are many Google Stands out there, battery life may not be a problem.
GeekGlasses67
