- Jul 20, 2010
- 8,558
- 1,252
- 113
First night with alarm clock app displaying time worked great, no battery fully charged pop up stuck on screen.It works on the regular heads up notifications, very well so far.
GREAT! The carrier still needs a complaint though. They shouldn't be allowing any notification that doesn't go away, that the user can't control without getting an app.First night with alarm clock app displaying time worked great, no battery fully charged pop up stuck on screen.![]()
When I put the phone on the wireless charger with clock on the pop up that says wireless charging goes away, only the fully charged pop up stays on.
The fully charged pop up needs to go away. I wonder if that happens on your Maps when navigating?
I will be emailing carrier to report, but for now it is good to have a fix.
Thank you, thank you, thank you.I found an app called Headsoff in the playstore that is supposed to help you turn off certain lockscreen notifications on lollipop. I don't know if it works or if it will help this situation because I haven't used the app. I read some of the reviews and they were good. Just offering a suggestion for those who don't like the new notification system.
I can't thank you enough, I started this post hoping there was something out there to fix this. You offered useful suggestion and it works. Again thank you for useful information, very much appreciated.
Mine goes away just fine with a swipe.
You can always throw the phone against a wall and it will stop permanently lmao
Sent from my SM-N910F using Tapatalk
Awesome.Mine goes away just fine with a swipe.
Heads up notifications are Notificatons that come up on top of any screen you are on.can anyone post some screenshots of headsup with settings ? i cant get it to help
i know that. trying to figure out what settings to use with the app called headsoff.
Isn't that nice. Love it.Well I tried it and so far so good... No pop up when battery is full... Yay!
From the Play Store download:
BATTERY FULL NOTIFICATION
That should fix it.
Note: Ignore the people who DO NOT PROVIDE SOLUTIONS, just bark at you here with their ignorant responses that are more annoying than the waking of the screen every night.
I totally agree, it is ridiculous that Samsung & Google designed such horrid operating system that won't give you, the user full access to customize, such as DISABLE ALL PROMPTS,
Here is another dumb thing Samsung Galaxy S5 does: Turns on the screen and prompts when wireless charging is achieved, or when you plug it in. Really???? So stupid. The LED light should just indicate a connection. We don't need to turn off the screen every time there is a connection or connection loss. Terrible job on the Lollipop and unfortunately on the Galaxy S5 and sounds like on the Galaxy S6 even. I am not a fan of the iPhone, but at least apple allows you to DISABLE ALL NOTIFICATIONS.
Seeing many reviews saying that headsoff isn't working for Samsung note 4 or doesn't work on the lockscreen. I installed th3 free version and didn't notice anything other than the 'download the Pro version " spam notification from the app. I want confirmation it works completely for Verizon Note 4 before paying for it.
