mlblack16
- Apr 29, 2016
- 1,441
- 899
- 113
I never heard of this help me understand this goes on top of the bezel or does it replace it?
Search Amazon and you should easily be able to find them.
They have a strong adhesive and adhere on top of the existing bezel. They're very good quality, and I can vouch that the stainless steel option matches the watch case extremely well. The cost is around $25 depending on which material you select (aluminum or stainless steel). They're also very thin, so they don't add bulk, yet surprisingly strong.
FYI, I used a hair dryer with low heat to warm the adhesive on the ringke before applying to the watch bezel. I did this so I wouldn't have to push so hard to install.
