loving nova prime :) on my note 3 .
Here's Simple View using Nova Launcher Prime and UCCW. Icons are Click UI
Sent from my VZW Samsung Note 3
Sent from my SM-N900T using AC Forums mobile app
Does Nova (and Apex and other alternative launchers) work on top of Touchwiz, i.e., does it add overhead in terms of CPU and RAM usage on top of TW?
Or does it completely replace TW? Or partially, so that TW features such as the S-Pen and Air Gestures etc. are still available?
It's more of what you describe as "partial". It essentially replaces the homescreen and app drawer, and no, it doesn't add overhead in terms of CPU and/or RAM. Because of this, most of the TW-specific widgets won't work (I haven't tested all of them), but actual TW features, such as S-pen and Air gestures, etc., all still work perfectly.
What are some examples of TW-specific widgets, if you don't mind? (don't have the phone yet)
Will Nova interfere with MDM software like Airwatch?
Gotta say - Nova Prime is so much better to work with than TouchWiz. Faster, no negative battery life impact, and highly configurable. I'm glad I switched.
I switched 5 months ago and I love it. It makes my one feel more like pure vanilla android.
Sent from my HTC One using AC Forums mobile app
I just love having a unified UI between my N7 and Note 3. I can find what I'm looking for regardless of device. I did disable icon labels on my Note though since I added icons.
Some of the widgets you guys posted are awesome. I bought AccuWeather Platinum last year so I feel obligated to use it but it's widget kind of sucks. I miss the TW AccuWeather widget from Gingerbread :(
Sent from my Galaxy Note 3 using Tapatalk 4
Thumbs up for Nova Prime! The only app I've purchased to this point.
check out -
Fancy Widgets
Android Does
https://forums.androidcentral.com/e...ls?id=com.anddoes.fancywidgets&token=Qtg9QrGU
Look into 1-weather https://forums.androidcentral.com/e...id=com.handmark.expressweather&token=DjxOOWn9
**FishenFool**
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Nova Prime also gives you gestures.
The gestures are awesome. I set one up so that when I double tap my screen Google Maps comes up with my home address pre-filled so that I can get quick directions home from whereever I am.
Checking both of these out now. Already digging Fancy Widgets integrating with AccuWeather!
Sent from my Nexus 7 using Tapatalk 4
I was using nova prime. Got this phone set up. Widgets for appy geek. Appy news. Appy gamer. And this site widget were all crashing. Can't get it to work. Any ideas? And yes I have 1 widget per page and 7 pages! Lol
Posted via AC App via note 3
just downloaded this after reading the thread. id have downloaded it just to get an extra row of icons instead of the dead space touchwiz has between the dock and the bottom row.
question, is there any way to edit the lock screen? id like to have widgets there with the pattern lock or something.
I don't think you can have widgets on the lockscreen unless you're just using swipe to unlock. Regardless of launcher.
Nazeer zaheen
