loving nova prime :) on my note 3 .
what do you guys use from the "prime" part of it? i'm just using nova free and not sure how much good "prime" adds...thanks
Mostly gestures, there are many available in Nova prime. You can also set up gestures on the icons at the bottom, which I find like a great way to relieve the home button from too much abuse. There's also Nova count, which will show a count of new messages on Gmail, SMS, etc.
All in all, a very much justified investment.
Sent from my SM-N9005 using Tapatalk
I hate the Notification Bar, I always hide it. I don't know why but Transparent is note available in my LG G2 but last night I noticed it is for the Note 3.
I don't think you can have widgets on the lockscreen unless you're just using swipe to unlock. Regardless of launcher.
Widget Locker for widgets on your lock screen. Awesome app.
EDIT - Dashclock very cool as well. :)
Could you get widget locker or dash clock to be the only widget on the lock screen? I tried them both and it seems Samsung interfered with them being the main lock screen. You would have to swipe right to see them.
Bobbman - my Widget Locker lockscreen has the following widgets on it: weather (Weather Channel I think), flashlight (use it way more than I care to admit), battery % (because my eyes are too old to see the tiny # in the notification bar), clock (same as battery %), Evernote, Jot, Officesuite, and camera.
I used dashclock for a bit and liked it, but don't currently use it.
Hope this helps.
Hope this helps.
the app reviews say you cant use a secured lock with widget locker
Would I be able to use Nova to make TW look more Holo, like in Jelly Bean? I hate the Gingerbread look of TW, with the green colors and the very dated overall appearance.
The home screen yes. Unfortunately the florescent snot colored quick menu items from the status bar will remain as TW, the launcher doesn't control those.
Here is a screenshot of Nova Launcher with simple text and HD widgets. Killer combo
http://img.tapatalk.com/d/13/10/22/ma2yvyma.jpg
What weather widget is that? Is it HD widgets? I have been looking for something like that. I am currently using Android weather, which is good, but I really like those quick toggles at the bottom of the widget.
Sent from my SGH-I717M using AC Forums mobile app
suri
