Low volume issue with Samsung S7 Edge?
markm75
169
My wife and i have two s7 edges.. on hers if i plug in the 1/8" jack to the car stereo and play music using any app.. the volume is correct and normal (louder).. ie: my car i set the dial to 15 and its plenty of volume..
Lately on mine, despite cranking the volume on the phone, to get the same level of volume (tried various apps/tweaks, no good).. i have to crank the dial to 22
Has anyone ran into this and might know what is going on? Or did my headphone jack suddenly become defective?
Thanks in advance
If you have the equalizer on the phone turned on, try turning it off.
I think the issue was the port itself (safe mode had the same issue).. certain times i'd insert the jack, it would be fine, while others not.. didnt seem to change volume while wiggling either.. so i blew out with air the port and so far so good..
yanis
