Mailbox
Re: Email addresses of flipboard and YAHOO news
Thanks.
Verizon Samsung Galaxy S5
Lollipop email
I'm planning on upgrading to lollipop 5.0. I have a samsung galaxy s5 using free non-stock programs. one Google CALENDAR , TEXTRA, and MAILBOX When I install the upgrade, will the stock programs be already on the device or will I have to add them separately. Have you had any experience with those new stock programs, email messaging and calendar? Thanks
Verizon Samsung Galaxy S5 Verizon network
Re: Lollipop email
From what I have seen on my T-Mobile S5 with lollipop, all stock programs are there and act the same as they did in kitkat, with some minor visual differences
Re: Lollipop email
Once you enter your Gmail account, your apps, free or paid, at the Google Play Store are going to download. If some free third party apps like SMS, Email or Calendar don't download after the upgrade to Lollipop 5.0.0 you just go to " My apps" at Google Play Store, then select " All" look for the specific app and download it. Check the screenshots good alternatives for your current third party apps. uploadfromtaptalk1424642576914.jpguploadfromtaptalk1424642592767.jpguploadfromtaptalk1424642603491.jpg
Sent from my Nexus 5 using Tapatalk
Mailbox to gmail
I've been using mailbox for a mail server. I switched to Gmail. There are many folders that are empty that were carried forward from mailbox to Gmail and I want to get rid of the folders. How do I do that? Thanks
Re: Mailbox to gmail
Ummm...to the best of my knowledge, GMail doesn't support folders. It does labels, but not folders. If these are, indeed, labels, you can tap the arrow next to the label (in the web client of GMail) and select REMOVE LABEL, or go to the bottom of the list and select MANAGE LABELS, where you can control all of them.
You might need to access Gmail via the web browser and edit the labels (I believe you are referring to labels, not folders) settings to delete anything you no longer need. This can usually be done by hovering the cursor over the label that you want to delete and click the down-arrow and choose edit. From there, select delete to remove the label so that it doesn't show up in your list.
Let us know if that helps or if you have any other questions.
Edit: Ha! I just posted right after SpookDroid provided the help above. Let us know if you have any questions.
Mailbox Help
I just changed to mailbox application from Outlook. There are some settings in the instructions, that do not work. I'm trying to organize my emails in chronological order. Is. I have there way to do that? Thanks
Verizon Samsung Galaxy S5 Lollipop 5.0
I gave up on Outlook mail. It's much too buggy for me. Thanks for looking at the problem.
I used to be able to hear a sound notification whenever new mail arrives. The new mail arrives in my Inbox but the sound
notification does not work. What am I doing wrong?
Re: New Mail signs have stopped working.
I assume you've already checked your Settings>Sound>Notifications menu, right? Also, open the Email app, tap Menu>Settings, and select the email account in question. Look for the notification settings--is it set to a tone other than "Silent" or "None"? Try selecting a new tone, and make sure it plays a sample for you.
I did all that. All the settings appear correct. I'm sure it's something simple. I just can't find it. Thanks again for your patience and help.
All other audio notifications working?
Mailbox archiving.
All of a sudden, my emails, MAILBOX, are not going into my inbox. They go to an archive folder with no notification. I had this problem several months ago. But I don't remember how I solved the problem. Please advise. Thanks
Re: Mailbox archiving.
Is it all emails or just a few from a particular sender? I think you might have accidentally set a filter to send all incoming emails to Archive. Take a look at this page on filter support: https://support.google.com/mail/answer/6579?hl=en
You can follow the process to see which filters you have set then either delete or modify accordingly. Let us know if you have any other questions.
Sending group emails
I have a samsung galaxy s5 smartphone. I can set up Group contacts in my contact folder but cannot send group emails in my email client, MAILBOX Anyone have a solution to the problem?
Re: Sending group emails
This is one of the few inexplicable deficiencies I've encountered in Android. If you use Gmail, you could use Gmail Group Share. Not sure what options there are for the stock Email app, though.
Thanks. I thought it was just me.
AquaMail will do email to your contact groups. Very easy. When you start a new email at the left end of the 'To' field tap on the little people icon. Your contacts list pops up and across the top is 3 choices - Contacts (the default) Groups and Recent. Tap on Groups, select a group and everyone in that group is added. You can deselect individually anyone you don't want to send to. You can even select multiple groups.
AquaMail is just the best.
https://forums.androidcentral.com/e...s/details?id=org.kman.AquaMail&token=kyy_AQRj
Android since v1.0. Linux since 2001.
RockoAndroid3689
