mclarryjr
Retired Moderator
- Nov 2, 2009
- 5,577
- 939
- 113
Er... say what? I used Firefox to download the file... I still get the error.![]()
I used firefox too so that's not the problem.
I can see extensions on my setup. In fact removing the extension prompts Windows to warn me about the file extension change consequences.
I placed the file at the root, powered off the device, turned on holding the X key. Pressed Volume+ + Camera once the /!\ screen appeared. select the second option to update the phone and then starts and the error message appears in nice yellow font.
My shortcut would not work on my home screen for the Gallery. I deleted it and put it on again and it works fine now. The update must have replaced/updated the gallery portion of the system.
I would try deleting from you pc and try downloading again maybe something was wrong with your first download.well... I swapped the file name from update to update.zip that seemed to work for a bit until I get this:
-- Install from sdcard...
Finding update package...
Opening update package...
Verifying update package...
Installing update...
Verifying current system...
assert failed: apply_patch_check("MTD:boot:2512896:86ce122fdfab1ca7aea268575ec692699c8556ab:2502656:e79414e177b152c9c3eca09f1be0c6b1b24e889")
E: Error in /sdcard/update.zip
(status 7)
Installattion aborted
It all lasts less than 20 seconds.![]()
I downloaded from here AllDroid.org - View topic - 2.0.1 Update.zip , which I pressume is the same place everyone else is getting it (am I wrong?). It's already looking like a lot of trouble... gah!
Everyone keeps saying rename to update without the .zip. All wrong. The actual file name has to be update.zip or it wont work. Some people have different file display settings which will show all file extensions. If you have it set that way changing it to update removes the .zip completely
Yes, I saw that. But that's more trouble than I wanna go through. I'll just wait for it to come.![]()
