Max SD card size?
Is there a minimum write speed to look for?
Depends on what you are doing. Class 4 is fine for media. If you plan to record 4k,I would have recommended class 10 . keep in mind not all class 10s are created equally.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
Hmm I went to radio shack and got myself a nice 64 gig anything bigger is irreal Ivan as I have a locked boot loader and unlimited data and my music's in the cloud
must have unlocked boot loaders!!
Most big capacity sd cards I've seen, like 64gb, are either class 10, or UHS 1, rarely any 6. The price difference between a lower class and top of the same size is usually negligible, so just pick the fastest, it kind of implies better quality too.
Honestly SanDisk is the original oem of micro sd cards and they have lifetime warranties it's not impossible to fry one or get a defective one but they are a bit pricy but all 5 of my SanDisk cards still work and I've got some from 2010 froyo days..
The 64 GB cards work in the S4. If anyone is looking to buy some I got a bunch im selling. They are 64gb class 10. Message me if your interested.
Too bad I went to radio shack and got mine
Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
Test? How to test it???
I just bought a 64 sandisk and I'm having loads of trouble with it.
How do I test to see its real size??
//S
This happened not because the card was slow or of an incompatible size, but because the card you bought was either a knock-off from ebay/amazon or somewhere else or damaged internally. That's what happens when they fake the size of the card by modifying... lets call them internal 'parameters', to show it as higher capacity, but in reality, its just a low GB card. Therefore, the card rejects any new files, and if it accepts them, they show up as corrupt, since there is no more space for it store more data. It just stores a 'pointer' to a non existing file in the partition table.
How to test it? I'm having so much trouble with a newly bought 64GB Sandisk SD card. Been trying to copy files over on it for days now and it just doesn't seem to work properly. And when I put the sd card in my phone, some of the folders have corrupt names...
How can I make sure this is a fake one so I can take it and shove it up their ---s?
Trevor, are you saying that you are using a 128 GB Micro SD card in a Samsung Galaxy S4? You said you had to format it in your PC. What program did you use to format it, and to what file system?
dmflowsjalallodhi
