Mechano watch face for the Gear S2/S/2/Neo
Thank you!
There's no way to change the ambient mode brightness, that's handled by the watch itself, but the tick marks can be added. The only problem is that I can't add them to this Mechano version because it's designed for the Gear 2, Gear S and Gear S2. I could only add the ambient mode on a watchface made only for the Gear S2. However, I'll try making an upgraded version of Mechano exclusively for the Gear S2.
In the meantime, I suggest you take a look at Watchland, it's a new app I'm working on which has tons of faces, many of them with ambient mode. Plus, I'll be adding a default ambient mode as well :)
I LOVE seeing the activity on this thread, especially from the developer. Great Job!
I just got my Gear S2 today and this is the first app I bought for it. After reading this thread and watching your video's as well as the feedback, I thought I would give this a go.
No regrets, so THANK YOU!
I am also of the mind that I can do without the notifications and have a steps counter instead. That is the only thing i can imagine changing to make this the only watch face I'll use.
Thanks!
Thank you for the nice comment! :)
The pedometer should be available soon, Samsung rejected the last update, so I need to fix up a few things, and then I'll submit the update.
I also suggest you check out my new app, Watchland, which allows you to put hundreds, and soon thousands, of sweet and free watchfaces not available on the Gear Store on your Gear S2. :)
There's a thread in this category about Watchland, you can check it out!
I will check that out now! Thanks again for the update and response!
Michael Carvalho
