Media volume too low -- Skyrocket
dmarquand
18
I have this re-occuring problem with the media volume being very low even at full blast. I've tried it on three headphones so I know its the phone. Rebooting it works great, but I need a full solution.
I'll start to notice the battery status when this problem keeps happening, I was thinking it may be due to low battery?
When it does this, is the media volume set to 100% on the slider bar?
Sometimes the apps may adjust the volume for whatever reason.
If it's at 100% then I dunno. You might try clearing your davlick cache to see if that helps.
Or reflash if you're on a custom ROM.
Thanks, but I found out it was all PlayerPro's fault. That's the only thing I use for media sound. I downloaded PowerAmp and its much better.
alshrmani 77
