[MEGATHREAD- Gionee file/folder decryption problems]
  • Start date Start date
A
AC Question
How to decrypt the encrypted videos in gionee m5.???
Recently, i encrypted some videos and now i am not able to look for them, nor find a way to get them back
mobile gionee m5
Re: gallery n camera not working
Welcome to Android Central! Were the photos saved to Internal Storage or the SD card?
Have you already tried using a file manager app to look in the /DCIM/Camera directory (if these were photos you took with the Camera app), to see if the actual photo files are still there?
Did you use a Move command for any of these files before they were lost?
How to decrypt an encrypted photo in phone
I accidentally encrypted photos in my gionee phone would you please help me decrypt those photos
Re: How to decrypt an encrypted photo in phone
Did you enter a password to encrypt them? Then use the same password to decrypt them.
I've got a Galaxy J3 Extreme phone and a Galaxy Samsung S6 both have encrypted photos in them how do I decrypt them. I really didn't know encrypting my photos meant. Can I get help with this please?
I accidently encrypted my pictures
Im using Gionee A1 s6s I accidently encrypted my pictures how do I find them
Encrypted some photos phone stolen but backup is there.How to locate encrypted photos?
I have encrypted some photos in my Gionee elife e7 using inbuilt encrypt feature. Now my phone is stolen but I have backup of my phone and I want to recover encrypted photos. Where photo is stored and how to recover it?
Thank You!
Re: Encrypted some photos phone stolen but backup is there.How to locate encrypted photos?
Unless you encrypted the photos with an app that used a password, you can't. Encryption by the phone itself depends on a few things in the phone, like its IMEI number, which is different for each phone. (Backups should be unencrypted - then you can encrypt the entire backup with a method you can use to decrypt the backup without needing the phone.)
The up side of this is the thief can't get at your pics either...
You use the same password to decrypt it as you used to encrypt it - there's no way to get around encryption - any encryption. (Encoding, like the Enigma Machine, can be broken, encryption can't be.) And since most phone encryption depends on the phone's IMEI number as part of the key, there's no way anyone could figure out your decryption key without having your phone. (Assuming that the encryption method was so weak that someone could figure out how to crack it.)
how to release the encrypted number? i
my phone gionee p5w how to release the encrypted number i forget the password
Re: How to decrypt encrypted in my gionee s6
Decrypt what? The phone should decrypt when you put in your password or PIN.
Re: How to decrypt the photos in gionee p7 max?
I'm assuming that on your device you are able to view the photo. If you share it to any other app or cloud storage it will appear as normal, however if you pull your SD out and attempt to view it via a card reader or by putting it into another device it will appear as an encrypted file. If you factory or hard reset your device without transferring encrypted data as regular files it will become un-recoverable.
Ulaburgang
