[MEGATHREAD] In coolpad note 5 fingerprint app and setting option is missing
  • Start date Start date
Status
Not open for further replies.
A
AC Question
Hlw frnd, I'm Nakul my contact no. [removed] frnds mere pas Coolpad note 5 mobile ek din isme setting mai se fingerprint lock ka option ka gayab h gya i did reset again n again but fingerprint lock r not come back I am very sad pls any one help me
In my Coolpad note 5 finger print app is Missing and i cant use finger print please help me
Why finger print unfortunately stopped
In my mobile coolpad note 5
The finger print locker was not working and system shows
The finger print locker was unfortunately stopped
what can I do for this?
Give me some solution for this
Re: Why finger print unfortunately stopped
We have no solution to this problem. Contact the manufacturer's customer support.
Re: My Coolpad note 5 fingerprint app is disabled fingerprint also not working
It may be best to contact the manufacturer customer support.
Re: Fingerprint Sensor not working in my Coolpad Note5. Fingerprint settings also disappeared!!
See the linked thread above.
Re: In my Coolpad note 5 finger print app is Missing and i cant use finger print please help me
Just go to lock screen&setting - tap on screen lock option- and select option "None". Then the message will appear that this will disable pattern as well as finger lock(Just click OK). Now done. Now you can make new finger scan as well as new pattern or slide lock. Hope this will resolve your issue.
Fingerprint app is missing and sensor not recognised
Hi, I'm using Coolpad Note 5 for above 1 year. Suddenly fingerprint app is missing in my device. Then fingerprint sensor also not working. Please anybody tell me the possible solutions to solve this problem...
Re: Fingerprint lock app missing for setting option
Thread reclosed because there has been no helpful feedback to the fix suggested above, nor indeed feedback to any of the help and suggestions offered in this thread.
Answer already offered. Thread closed.
Re: My mobile coolpad note 5 in fingerprint missing you can help me
The sensor is missing? Or the software to enter a new one is?
Re: how to solve this problem
Contact the manufacturer. Others have had the problem and we have no solution here.
Status
TechEnthusiast88
