[MEGATHREAD] Why can't I save a contact name with emoji
Jan 6, 2014
Emoji's on contacts?????
I have the emojis and i can use them anywhere on any app and text messaging but i cant put them on my contacts. .. am i missing something here ot is it not even possible yet?
Thanks
Re: Emoji's on contacts?????
Woot woot! I have a LG Stylo 2 this is what worked for me! So I tried to download True Contacts and my device wasn't compatible so I got SwiftKey board and this app called Drupe. Once I set up my keyboard I opened the Drupe app updating my contacts using the emojis from SwiftKey board. I saved the contact and it switched on my LG Contacts as well!!!!! Both apps are pretty cool so if you want to keep them it wouldn't hurt
I hope this helps
Why can't I add emojis to my contacts on my Samsung galaxy j2
It doesn't show any emoji option just voice search please help
Re: Why can't I add emojis to my contacts on my Samsung galaxy j2
Emojis are just a couple of text characters - the app you're in translates them to emojis. Contacts doesn't translate text to emojis, so there's no reason top put them there.
how do I put emojis on my contacts with a sumsang j5
How do you put emojis on your contacts with a sumsang galaxy j5?
Re: how do I put emojis on my contacts with a sumsang j5
Welcome to Android Central! What do you mean by putting emojis on your contacts? Do you want to edit their names to include emojis? Or replace the contact photo with an emoji?
I'm using a J5. Why can't insert an emoji next to my contact names but my friend's J7 prime can ?
Re: I'm using a J5. Why can't insert an emoji next to my contact names but my friend's J7 prime can
That depends on the keyboard. Look for emoji keyboards in Google Play and install one that has the emojis you want. (And remember, emojis are just text - it's up to the phone receiving them to translate them into pictures, so if the person you're sending a text to doesn't have an emoji that you send, it won't show. The standard ones like smiles and frowns will, but some of these emoji sets have things that the "developer" made up, not realizing that only people using his emoji set will ever see them.)
Why u cant put emojis next to ur contact?
Your normal keyboard does not support that but there is a way
Download [app name deleted] then u will be able to
Follow me on instagram [personal details deleted]
Why can't i put emojis when saving contacts
How is it possible that emojis can go anywhere on my Sansung Galaxy J3 Verizon but not when saving contacts?? I don't really understand.
Re: Why can't i put emojis when saving contacts
Some contacts apps do not allow it, so do.
My current LG phone allows emojis in the contact names, my previous LG phone did not.
Why cant i use the emojis when saving a contact name
When i want to save save someone name in my phone with emojis it does not work
Re: Why cant i use the emojis when saving a contact name
Names are alpha-numeric. A name field won't take an emoji.
Like for instance when i reach contact my keyboard don't have emoji anymore and I want to do sth like
kim💋💋
Which keyboard are you using? I can add emojis using Gboard on my Pixel 2 XL. It could be a limitation of your keyboard or your phone.
sellhousefastmke
