Messed up SD card after using MiniTool Partition Wizard
Have you tried diskpart, it worked for me recovered a bad card.Run these commands from a command prompt one at a time.
diskpart
list disk
select disk #
clean
create partition primary
select partition 1
active
format quick fs=fat32
assign
exit
bro u should try the partition recovery wizard of minitool then wipe the partition ,finally go my computer ->manage->Disk management->see your memory card there->change drive letters and path ...hope it will help..
kutty7
