Migrate S20 5G from T-Mobile to Verizon?
Got stuck after Odin said "pass". Gave option to factory reset/wipe or try again which led to the same screen. Finally booted up but started in Tmobile screen again. Waiting for smart switch to finish up then I'll restart the phone and see but it doesn't seem like it worked. Was not a smooth process. Only thing I didn't see, perhaps because it didn't work right, was
Put your model number,region select check for updates , then download the Rom , extract the Rom with 7zip.
I read the "super easy guide" and followed that before I saw your reply.
Use those tools I mentioned for Verizon firmware, use csc home data so don’t factory reset
Tried again, same end result. Odin shows it was successful but the phone gets stuck and requires factory reset and then the phone is exactly the same. I downloaded off the samfirm website, I can't get the samfirm tool to update to show the 981 firmware, just gives an error. I found another site that has the vzw firmware but you have to join and pay for it. Luckily I have my note still so I can smart switch back and forth which is great but it is a pain. I found a 981u1 firmware that has the vzw version but it didnt work at all, Odin failed within seconds. Is it possible the phone is locked to Tmobile and can't be changed??? The firmware I am attempting to use is "SM-G981U_G981USQU1ATBN_G981UOYN1ATBN_CHA_10_5".
Sorry, I am just at a loss here. Making things more difficult is my personal computer won't recognize my phone so I have to bring my work computer home and I'm a little apprehensive about downloading from some of these sites that I have googled what I think is the correct firmware.
If you want go from carrier to unlocked firmware you need odin 3.13.1 prince comsey and this will factory reset
I think I was using 3.14.4 or whichever the latest was. Since I can't get the vzw firmware on the samfirm site and cant get the software to update are there any other trusted places I can get it?
When using the one I listed there are no errors, it appears to work fine except when the phone restarts it has the option to retry or factory reset.
Retry or factory reset ? Where did u see that?
It looks like the same screen as when you start up holding the up and power button, how you get into the download mode except there are only 2 options.
Ahh recovery
So after you flash , it takes you there ?
Correct. I tried "retry" multiple times and finally did reset which got the phone properly started up.
Very strange , it should of took you to a screen that say optimizing 20 of 400 apps then boot up to lock screen.
Did you put all the files in their corresponding slots?
We take a break Tonight, ill go to my computer at work where I have my samfirm and odin , we can go over everything from there
I can't find the verizon firmware and samfirm doesn't show it. I really appreciate the help, I'll check back tomorrow.
witnessloc10
