MIUIGb[WIP] 10-20-12
Status
Not open for further replies.
Re: Miui gb[wip] 7-9-12
if anyone is running please try this to fix themes
use a file manager apk
to get install a apk or something
make a new folder in the /data/system called "theme' without quotes this should fix themes
if not i will still work on it
OP updated fixed themes and fixed play store(YAH) synced with gannons latest build from vmroms didnt see his new build on android central so checked vmroms and there was a newer rom version availible so lets see how this plays out
@ThatGuyLurkin heres framework file framework.jar framework.jar
edit this and pm it to me when your done fixing mms
My latest build doesn't have gapps included. The reason it didn't boot was because of the included gapps.
Sent from my PC36100 using Tapatalk 2
If you really want to make it better the biggest thing I would work on is speed and the installing non market apps issues. Those were the two of my biggest issues.
Are you aure that's not a problem with MDPI miui?
I've looked it up a few times, and speed is impossible to gain.
Apps, Ive seen people with the same problems. Alot of alls don't work :/
Hmmmmm non market I will work on btw gannon I
Ur a rom building monster to make something like this
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
Test your S, their both siblings. :)
ugggggg
ok i might
but tommorow because im trying to work on my secret project :p:eek::eek::eek:
it will put impatient jellybean lovers in their place :eek::eek::eek:
havent tested it though dont even know if it boots
plus i just got cozy with cm7.2,:(:(:(
TheKravens cm7.2. 3.7
amphetimines
kodev ics theme
787 MHz
smartassV2
ugggggg
ok i might
amphetimines
kodev ics theme
787 MHz
smartassV2
Yo kid throw me a link I got you for a test :D
GTR, AOKP, MiRaGe, CM9, BOBZ ICS, GODZILLA, Harmonia 2.08 killing the game!!!!!!!
Reactions: jonny5449
Status
TheGreatApe00
