MIUIGb[WIP] 10-20-12
Status
Not open for further replies.
Going to put some time into this on Monday or Tuesday sorry for delay I noticed its kinda laggy even overclocked to 748 Max so will work on that
Mms awaiting TGL :D:D
Non market I'm stumped
Themes I THINK work
So will work on it sorry for delay
Sent from my LG-LS670 using Android Central Forums
Possible lag solution is to resize all the images in the rom to mdpi so the phone doesn't have to do it while it's running. You risk limiting theming though.
Imo its worth it. I'm using Martinez's miui and pretty smooth(; but I'd love to give this one a try I love flashing new roms!
Re: Miui gb[wip] 7-9-12
Aren't all the images already MDPI? That's why they were able to base it on CM7?
Also, Did you PM me the framework.jar? I forgot. I'm downloading now.
images don't have to be mdpi for the apps to work on mdpi devices. mdpi devices resize the images while you're using the rom which is why it lags since it has to resize thousands. koloses's miui rom also lagged on his phone because of the images so he decided to resize them all and it became smooth. i haven't checked the images on this rom but if they're hdpi then they need reszing to fix the lag. if they're already mdpi then the problem is something else.
It is impossible to edit a Java file related to Android without decompiling it
Download the APKtools via the website(Google it) and copy what you need to the Windows Directory.
Its really easy xD, it 3files that you put in the Windows Directory and your done
Status
BarishYadav
