[MOD] GPS fix v3 4/21
Re: [MOD] GPS fix
Not accuracy threshold.... that should stay at 0 or something between 150 and maybe 300 (distance from your true position before "lock").
But I haven't been able to find a definition to the intermediate position report (INTERMEDIATE_POS=0). I would be curious to see if changing it from 0 to 1 makes a difference.
Re: [MOD] GPS fix
Oh okay. Gah, I'm an idiot. lol. I totally had read that wrong. After seeing this and playing with it, I'm curious to see what the one in Kraven's CM7 looks like because I've always felt like that had great lock on.
:EDIT: Okay, so I downloaded a build, and checked the gps.conf Here's what I found. Also, it does have explanations that might help regarding intermediate and such.
I'm unsure if this would work on ZVJ? Not sure why it wouldn't as it's written for a GB ROM albeit a different version.
:EDIT2: Removed text so as not to confuse people. Adding file for OP to compare.
The attached file is NOT the GPS fix please refer to post #1
Re: [MOD] GPS fix
So you just have to flash the zip or do you have to do it manually? :-\
Re: [MOD] GPS fix
Hmm... I'll spend half my day on INTERMEDIATE_POS=0, then change it to 1 at lunch and see if I see a difference....
Ok, I noticed that on a setting of 0, my location circle continually expands and contracts, but a setting of 1 seems to stop that from happening. When I get home tonight, I'll update the zip to v2...
Re: [MOD] GPS fix v2 4/19
There a program in the app store called faster fix. Does that do the same thing?
I looked at the faster fix app on the market and all it says it does is change the servers to your region of pool.ntp.org.
Is everyone happy with this mod? Does it seem to help the speed of locking in on a gps signal over the stock?
I flashed the file and it seems to lock faster. I've noticed that when i'm using the navigation and it loses the gps signal, it locks up, freezes and has to force close. Is this because of these files not allowing the gps to relocate itself or some other reason?
Also, another observation is that when I close maps, or any other gps based app, sometimes the gps signal stays on. Is there a fix for this?
I've never seen it behave that way. What ROM/ kernel are you using?
Hydrokernal v.3. I've uninstalled and reinstalled maps, and reboot. I will be testing it later today.
I'm sure we all have times that we lose the gps signal. The question is what happens when it comes back. In my case, it froze. I'll have to see if the changes have helped. Perhaps it has nothing to do with your gps zip.
btw, as far as the file, is it suppose to give me a more accurate location? If so, what should I notice with this as compared to stock?
What I've noticed was a much faster lock and I don't loose lock. I don't seem to get gps lag either, just from navigation. When nav is lagging, everything is lagging.
not that I'm aware of. I've noticed that zvj or the hydo-kernels seem to have a higher drain. I had cm9 melt down on me today (with gb hydro) and I had to nandroid back to reborn. I then flashed the gps fix and my battery drain went away. I think Drew is aware of the ICS hydrokernel battery drain.
I'm not on ics, i'm on ginger rom and hydrokernel, (non ics version). Do you find a big difference in performance of the gps system using your fix on this custom rom/kernel combo?
tuovst
