More phone woes...what should I do?
Ok so question lol. First the phone is running fine. The apps installed faster than ever before. Seriously last time it took me hours. Ive had no issues at all. So my question. The launcher thingy at the bottom (remember Im just a chick with a phone I dont know all the technical terms lol) is there a way to change it? It has just phone which I never use, browser which I use but dont need there, and apps. It would be nice to have more than the 3. And is it just me or did we have like 7 (?) pages before and now there are 5? Can I add more like I can with my Tab? Seriously if I cant change these things Im fine but if I can that would be great. Thank you again and I definitely owe you guys pie, coffee and beer!
You can't change them with the launcher included with superclean. You can go to the market and download a different launcher. The two most popular seem to be Launcher Pro and ADW. And I think most people here are using Launcher Pro. Both allow you to customize the icons down in the dock (that's what that box with the three icons is called), how many homescreens you want, and a ton more
Reactions: melissasroja
I delete the launcher2 in the system app folder and put my new launcher in there. You move it from data app with rooot ezplorer.
Sent from my SCH-I500 using Tapatalk
Ok so I like Launcher Pro. I tried another. Go Launcher? Something like that. Didnt like that one. Launcher Pro is great though. What I dont know is if I make it default how do I switch back to the regular launcher if I have to without uninstalling Launcher Pro?
go to the market and get home switcher
LP tips
from home screen>menu>prefrences>advanced settings>memory usage>High
from home screen>menu>prefrences>homescreen settings>transition effect>and pick one and also enable virtual looping
Hit menu soft key and go=>settings=>applications=>manage applications=>all=>launcher pro, click on it, then click on clear defaults. When you hit the home soft key from there you will get a pop up which will ask you what program you want to use to complete the action, just click on launcher instead of launcher plus.
Oh wow yep that did it! I tested to be sure you were right lol. Not that I didnt think you were of course! I assume its the same thing with Dolphin vs standard browser. Great! Ive been afraid to select Dolphin as my default for fear of not being able to switch it back lol.
this works but home switcher makes it convinent to switch back and forth
Why would you ever want to switch back from Dolphin HD? That's blasphemy :p
Ill add home switcher to my list of things to investigate!
I love Dolphin but for some reason one of my sites tends to lag. Its a bunch of drop down style entry boxes and it works good with the default browser but not Dolphin for some reason.
I just added both to my what did you call it? Dock? And I love love love that I can scroll through the bottom dock thingy. That in itself is awesome.
What is the difference between free and paid Launcher Pro? I usually try to pay if I really like something.
I just upgraded to the paid version yesterday mostly just to support the developer because I like the free version. I now you get more widgets with the paid version. I was able to do a backup of my homescreen and launcher settings. Not sure if you can do that with the free version because I never tried.
affansahab2021
