Motorola Droid Turbo: Screenshots & Homescreens
Re: Motorola Droid Turbo : Screenshots & Homescreens
Todays
Here is my homescreen.
Nova Launcher
Mix of a few icon packs.
Plain-Jane stock.
Re: Motorola Droid Turbo: Screenshots & Homescreens
Here's mine for now. You could say I like ingress, lol. Did all the icons myself. Okay, just played in Photoshop and image searches, but still proud.
Minimalistic look for now. Nova Launcher, UP icons. Bought HD Widgets hoping to find a clock/weather/battery widget to replace the Moto Command Center but didn't see anything that grabbed me.
My current setup on my Turbo. Stealthychief Viper icons, clock widget from RX Series by Rod Kucheran (tweaked by me) and wallpaper found on G+ Android Wallpaper community.
Try Zooper... You can design your own widget. Here's my home screen. I also wanted something that functioned and looked like the Command Center without the battery drain, so I modeled this widget after the Command Center.
Forgot to attach a pic in my last post. This is the Zooper widget I modeled after Command Center.
Running Nova.
I haven't noticed command center to be much of a power drain.
Thanks. It's Jorte, specifically 5x1, then stretched wider. I have nova's spacing set to 6 wide, with sub grid positioning.
Thanks for sharing. Doesn't appear to support Google calendar (yet?). Will keep an eye on it.
Finally got my tudia teal case in the mail and needed something super minimalist to accent the case. I kinda like this look
shahg
