Multi view update on December 27th!
Apparently we got the same update as Poland :)
androidos.in/2012/12/samsung-galaxy-note-ii-android-4-1-2-update-roll-out-starts-with-poland/
At least. I'm at 4.1.2 with the jzo54k build. Kernel date is 30 Nov.
In anycase it's the same as the release for the N7100 model. However, does anyone know how to customize the notification shade? Some ppl said they can't.
++ of they're anything like how Motorola used to do them, it was sort of by random IMEI within a region. They would pump out out to some in a region and then keep going region by region until all the regions and subscribers within each region had it. But they wouldn't push to an entire region, then to the next region. But this could be completely different?
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Honestly for these folks, I am not so concerned about the fact that the update is not there for them.
The update not being available could very well be a region or market related issue for which there is no easy workaround.
I am more concerned about how the AT&T Software update service is allowing that You May Check Again in: XXX hours setting to go above 24 hours at all.
Sure, the ability to bump the date and check for updates twice in the same actual 24 hour period is an exploit, but for the AT&T Software update service to allow that number to go ABOVE 24 hours at all is just shoddy.
I loaded the software from an APK. It didn't come with my GN2, Google photo editor apk and you can load it on the phone.
Nothing here either, Peaches. 7pm Chicago time. Tried the trick to set one day up and nothing. Just doubled my time to check again. :(
Thank you. Not many people are getting " notified " abt the update. As per AT&T and Sammy support said we will. I dont think they know what their doing.
I tried this morning and it told me I had to wait 12 hours to try again.
All AT&T Regions will not be notified all at the same time, seems to be staggered so everyone isn't downloading all around the same time.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Can you explain a little clearer. I cant find photo editor. TIA
Use your S pen. Press and hold the bottom on it while pressing the S pen on the screen. It takes a screen shot and then takes you to a editing screen
Has anyone figured out a solution to the "software update interrupted" message when trying to check for update? Mine has said that since I got it on release day. Called AT&T today and they couldn't give me any answers or reasoning. When my S3 did this I was told it was a hardware issue, replacement phone worked great.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
Can some one please see if HBO GO is broke for them also? I can open the app and navigate in it but once I try to play a video the app freezes for about 2 minutes. Worked fine before the update. Netflix works fine. I did try un install and re install.
Still nothing in Chicago.....172 hours to recheck. I'm not altering the time again-doesn't work :(
Yea im at jan 30th 2013 for the clock trick. In louisiana and still nothing. Ill try again in 2.5 hrs
Got this morning we live in Alaska. Just figured out the double window pretty cool, just wondering what else we got with the 174meg download.
vickyy
