Multi Window Compatible Apps List & User Guide
Re: Multi Window Compatible Apps & User Guide
I'm not in the UK or Ireland, so I cannot install the app. Also, I cannot find any info that this app is compatible with Multi Window. Can you point me to something that shows that it is compatible?
Oops.. I was hoping all apps can be made compatible to multi window if you know how to work your way around it. My bad
Podcast. addict https://forums.androidcentral.com/e...staddict&feature=search_result&token=_QI4JCGk..
Battery history&indicator.https://forums.androidcentral.com/e...nMuQmF0dGVyeUhpc3RvcnlGcmVlIl0&token=BJCSFp5Z.
Stopwatch&timer. https://forums.androidcentral.com/e...9zb2x1dGlvbnMuc3RvcHdhdGNodCJd&token=YVh-VjFZ
Re Cheech Chung and others: so cool that this thread is being followed by ppl from all over the world-but that's the beauty of the internet: it connects ppl with common interests regardless of geography or age
No Chivers around here?
KCCO Pro is multiwindow compatible.
From my Galaxy Note 2
It's already on the list under entertainment. Along with their sister sites. Berry and brigade.
Sent from my SPH-L710 using Tapatalk 4 Beta
speak your appointment. https://forums.androidcentral.com/e...ad&feature=more_from_developer&token=b9Owc3lO.
image editor https://forums.androidcentral.com/e...geEditor&feature=search_result&token=IIl89HkS
ebuddy messenger https://forums.androidcentral.com/e....android&feature=search_result&token=bo_RpDWr ( although I think it's on the list smwhre)
MISCELLNS
would it be appropriate to put multiwindow shortcuts ( https://forums.androidcentral.com/e...mMuc2Ftc3VuZ213c2hvcnRjdXRzIl0&token=KdMMN3ep.) somewhere eg at the bottom of the list instead of the add-ons, or under multitasking etc ? ( for those few who do not know about it)
Added, thanks!
MISCELLNS
would it be appropriate to put multiwindow shortcuts ( https://forums.androidcentral.com/e...mMuc2Ftc3VuZ213c2hvcnRjdXRzIl0&token=ApPBaWZL.) somewhere eg at the bottom of the list instead of the add-ons, or under multitasking etc ? ( for those few who do not know about it)
Since this is an app that by itself is not Multi Window but makes further use of the feature, I did put it in the Miscellaneous List. If I'm not understanding properly, let me know.
williestringfield90
