Multi Window Compatible Apps List & User Guide
Re: Multi Window Compatible Apps & User Guide
translate. free. https://forums.androidcentral.com/e...tails?id=com.james.GGTranslate&token=Ib9BjmiB
text me ! https://forums.androidcentral.com/e...etails?id=com.textmeinc.textme&token=T2tmOc5L
OsmaAnd Maps &Navigation by OsmAnd
calculator hd. https://forums.androidcentral.com/e...niversal_solutions.calculator3&token=qVRIEPzk
i was under the imp that was already on the list but I couldn't find it
NOT SURE if mw:
1. tic tac toe. https://forums.androidcentral.com/e...?id=com.freeandroapp.tictactoe&token=6tSUX-1n
initially comes up as MW but later on reverts to full screen
1. ?? only for Verizon?
These apps keep coming up on different searches for multiwindow apps. I downloaded them on my device but they do not come up as mw. Not sure if Verizon carriers enable this feature ( mine is not Verizon)
espier browser. https://forums.androidcentral.com/e.../details?id=org.espier.browser&token=3RuBJx3l
one browser. https://forums.androidcentral.com/e...tails?id=com.tencent.ibibo.mtt&token=W2FbvaFg
chekbook tab. https://forums.androidcentral.com/e...pps/details?id=com.bmschecktab&token=MqKmT1SX
2. mw But requires root
GMD Spen control clearly has the MW feature ( I downloaded then uninstalled it for a refund)
Added, thanks!
calculator hd. https://forums.androidcentral.com/e...niversal_solutions.calculator3&token=btTMC_1_
Nope, not on the list... but I do want to put a warning out for this one --> this app is full of all kinds of crapware (I still put it on the list as it's not my place to decide if anyone else should install it or not.)
NOT SURE if mw:
1. tic tac toe. https://forums.androidcentral.com/e...?id=com.freeandroapp.tictactoe&token=Wl4EfV_H
Added, thanks!
espier browser. https://forums.androidcentral.com/e.../details?id=org.espier.browser&token=nHfYERrO
one browser. https://forums.androidcentral.com/e...tails?id=com.tencent.ibibo.mtt&token=9VAHtDrY
chekbook tab. https://forums.androidcentral.com/e...pps/details?id=com.bmschecktab&token=5v9AMi_U
These show up on searches most likely due to keywords that they're using, but are not compatible.
I don't add apps that require root. If you're rooted, then this thread doesn't matter as you can add any app to MW.
Sorry abt the latter apps -it was wishful thinking. Also good to know abt calc hd and other suboptimal apps as per prior posts.
droidedit. https://forums.androidcentral.com/e...s/details?id=com.aor.droidedit&token=I7nuYr-4
More twitter apps:
tweedle. for twtr https://forums.androidcentral.com/e...?id=com.handlerexploit.tweedle&token=GvIEA8p7
locTwit. for twtr. https://forums.androidcentral.com/e...s/details?id=lk.bhasha.loctwit&token=7cOjLu_I. this app appears in the mw tray but does not have real mw functions on my device not sure on others
Plume. for twtr. https://forums.androidcentral.com/e...etails?id=com.levelup.touiteur&token=icN0jIB1
No problem. I did the same thing when I first came across them.
Added, thanks!
I have a question. Has anyone had problems with Evernote appearing in the multi window bar? It use to show up, not it seems to be gone. :(
Sent from my Galaxy S IV using Tapatalk IV
I just installed it to check & it did show in my MW bar. Did you check if it's in your 'edit' window?
Multi Window Compatible Apps & User Guide for non-rooted devices & non-modified apps
Sent from T4b on my N2
Yes I did. I notice that it appears then disapears sometimes but now it doesn't show up at all. I'm going to try to uninstall it and reinstall to what happens.
Red_Nexus
