Multi Window Compatible Apps List & User Guide
Re: Multi Window Compatible Apps & User Guide
1.JW-bible NWT
2. mem calculator lite
3. Lecture recordings
(the developer of 'Lecture notes etc' made some modifications: - Lecture recordings no longer come up as an add-on to Lecture notes they are an independent app )
I am having trouble posting the google links here so I will post them in 3 separate posts, sorry
1.JW-bible NWT
Added, thanks!
Thanks for the list. Is Office Suite Pro the only office app that is multi-window compatible? And can these apps work on multi-window supporting Samsung devices other than Note II?
Yes the multiwindow feature works on other Samsung devices;) as for the office suite, poloris office 5 is a multiwindow supported app.
Sent from my Galaxy S IV using Tapatalk IV
My pleasure. CloudOn is another office suite that's compatible. If I find that an app is only compatible with a certain device or on a certain carrier, it's marked as so. If you find that I'm missing any info, please let me know.
I also experienced your frustration I dont like Polaris office I like Office Suite pro but would appreciate more variety. I sometimes use Evernote to edit WordDocs as an alternative to Office Suite.
Solitaire Megapack. https://forums.androidcentral.com/e...tesseractmobile.solitairemulti&token=aVn3TTcp
-another strange Playstore arrangement it comes up as a paid app on the google play website but it's free within the Google Playstore app for android
network signal. info. https://forums.androidcentral.com/e...s/details?id=de.android.telnet&token=A1fzZRwr.
comes up in my MW tray however does not appear to have real mw features ( resizability) on my device (samsung galaxy note 10.1 and carrier(non-Verizon).
Would smn pls check if their device allows MW ? thx
Yup, it shows in my MW panel but always uses full screen. If they get it working, let me know & I'll add it to the list then.
Trying to edit the MultiWindow bar to include SPlanner but doesn,t work... Seems that it is not compatible... Funny....
Ya, isn't it funny that they didn't make all of their own apps compatible with their own feature?
I thought Evernote is something like S note. Can it edit word docs too without losing the formatting?
alwinnn
