My IRulu power button is bent, and now it wont work. is there a way to fix it?
  • Start date Start date
A
AC Question
It slid off the couch and bent the power button in, now it will not work. Do you have a warranty on this product? Or is there anything I can do to get it fixed?
this is from my amazon receipt. Rulu X1s HD TFT Display, 4*1.5GHZ Quad core, 7 inch Google Android 4.4 Tablet, Dual Camera, Google Play Pre-load, 8GB Storage (Pink)
Warranties are for manufacturing defects, not damage. The phone can most likely be fixed, but I'd suggest a repair shop, not doing it yourself. (You could break something more expensive by trying to fix the button.)
pauldop1982
